LG Refrigerator Freezer Drawer Slide Replacement
  1. LG Refrigerator Freezer Drawer Slide Replacement, Unplug your refrigerator: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unplug your refrigerator before you begin your repair.
    • If you are testing or repairing the following items, you may also need to shut off and disconnect the water supply:
    • Condenser fan motor
    • Compressor motor and thermal overload device
    • Water supply valve assembly
  2. LG Refrigerator Freezer Drawer Slide Replacement, Open the freezer door: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG Refrigerator Freezer Drawer Slide Replacement, Open the freezer door: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull open the freezer door fully.
    El cajón extraíble está atorado porque se volteo una de las ruedas y no puedo sacarlo.
    Lupita - crwdns2934203:0crwdne2934203:0
  3. LG Refrigerator Freezer Drawer Slide Replacement, Remove the drawer and bin: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 LG Refrigerator Freezer Drawer Slide Replacement, Remove the drawer and bin: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 LG Refrigerator Freezer Drawer Slide Replacement, Remove the drawer and bin: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift and remove the upper pull-out drawer.
    • Lift and remove the main drawer bin.
  4. LG Refrigerator Freezer Drawer Slide Replacement, Remove the drawer rail covers: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 LG Refrigerator Freezer Drawer Slide Replacement, Remove the drawer rail covers: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 LG Refrigerator Freezer Drawer Slide Replacement, Remove the drawer rail covers: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use your finger or a flat-blade screwdriver to depress the two locking tabs on the right drawer rail cover.
    • Lift the cover off of the rail and remove it.
    • Repeat this procedure for the left drawer rail cover.
  5. LG Refrigerator Freezer Drawer Slide Replacement, Reassembly notes: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG Refrigerator Freezer Drawer Slide Replacement, Reassembly notes: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The drawer rail covers can be tricky to reinstall. Follow these steps to reinstall them:
    • Hold the drawer rail cover flush against the side of the drawer rail.
    • You should feel the locking tabs protruding.
    • Push the rail cover straight downward to install. It should click into place.
  6. LG Refrigerator Freezer Drawer Slide Replacement, Remove the drawer: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG Refrigerator Freezer Drawer Slide Replacement, Remove the drawer: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips screwdriver to remove the screw securing the drawer to each of the drawer slides.
  7. LG Refrigerator Freezer Drawer Slide Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 LG Refrigerator Freezer Drawer Slide Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 LG Refrigerator Freezer Drawer Slide Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift the front of the drawer up.
    • Pull the drawer toward you to release the drawer from the drawer slides.
    • Remove the freezer drawer.
  8. LG Refrigerator Freezer Drawer Slide Replacement, Release the drawer slides: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips screwdriver to remove the screws securing both left drawer slides.
  9. LG Refrigerator Freezer Drawer Slide Replacement, Remove the upper left drawer slide: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG Refrigerator Freezer Drawer Slide Replacement, Remove the upper left drawer slide: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull the upper left drawer slide slightly towards you to release the locking tab at the rear.
    • Remove the upper left drawer slide.
  10. LG Refrigerator Freezer Drawer Slide Replacement, Release lower left drawer slide and reposition it: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 LG Refrigerator Freezer Drawer Slide Replacement, Release lower left drawer slide and reposition it: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 LG Refrigerator Freezer Drawer Slide Replacement, Release lower left drawer slide and reposition it: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull the lower left drawer slide slightly toward you to release the locking tab at the rear.
    • Reposition the lower left drawer slide to gain access to the door switch connector.
  11. LG Refrigerator Freezer Drawer Slide Replacement, Disconnect the drawer switch and remove the lower slide: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 LG Refrigerator Freezer Drawer Slide Replacement, Disconnect the drawer switch and remove the lower slide: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 LG Refrigerator Freezer Drawer Slide Replacement, Disconnect the drawer switch and remove the lower slide: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Squeeze the door switch connector to release it.
    • Pull the door switch connector down to disconnect it.
    • Remove the lower left drawer slide.
    • If you are removing the freezer evaporator cover, likely only the left-hand slides may need to be removed. In some cases you will need to repeat the previous three steps to remove the right slides as well.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our  Answers community for help.
Bill Gilbert
crwdns2935283:006/30/22crwdne2935283:0
37,700 crwdns2915208:0crwdne2915208:0
crwdns2935297:0261crwdne2935297:0
Staff
crwdns2931471:0119crwdne2931471:0
crwdns2935297:020,935crwdne2935297:0
My drawer won't open fully. It seems to be the left side track is stuck stopping it from opening.
Tresa F Malone - crwdns2934203:0crwdne2934203:0
Tresa F Malone - just now Edit Delete
La corredera izquierda de mi frigorífico solo corre hasta la mitad
Raul Padilla - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 11
crwdns2936753:07crwdne2936753:0 64
crwdns2936753:030crwdne2936753:0 228
crwdns2942667:0crwdne2942667:0 2,046
