LG Power Screen Replacement
  1. LG Power Screen Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG Power Screen Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide a plastic spudger, or guitar pick, between the back and front panel at the bottom .
    • A metal spudger can easily damage your device. A plastic opening tool is always the only option.
  2. LG Power Screen Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG Power Screen Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Carefully pop the back panel off and place it to the side.
  3. LG Power Screen Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG Power Screen Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the thumb tab to remove the battery.
  4. LG Power Screen Replacement, Motherboard: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the eight 4mm screws along the side of the mid panel using the Phillips #000 screwdriver head.
  5. LG Power Screen Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG Power Screen Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide a plastic opening tool between the mid and front panel to remove the middle panel.
    • Place the mid panel to the side.
  6. LG Power Screen Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 LG Power Screen Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 LG Power Screen Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Detach the motherboard and touchscreen from each other by using a plastic opening tool.
    • The motherboard will then be free from the phone.
  7. LG Power Screen Replacement, Screen: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 LG Power Screen Replacement, Screen: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 LG Power Screen Replacement, Screen: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • After removing the motherboard, slide a thin plastic opening tool between the screen and the frame.
    • This step may take awhile, because of the glue keeping the frame and screen together.
    This phone is not difficult... Replacement takes 15 mins
    Timothy Fogg - crwdns2934203:0crwdne2934203:0
    I can't loosen the screws on the lg x power. Help
    Tim Buendia - crwdns2934203:0crwdne2934203:0
    how much is it cost to fix a phone screen
    David Wessel - crwdns2934203:0crwdne2934203:0
crwdns2935229:011crwdne2935229:0
Nadia Wilson
crwdns2935283:002/09/16crwdne2935283:0
904 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 4-6, Lacy Spring 2016 crwdns2935289:0USF Tampa, Team 4-6, Lacy Spring 2016crwdne2935289:0
USFT-LACY-S16S4G6
crwdns2947412:09crwdne2947412:0
do i need a replacement screen?
jj - crwdns2934203:0crwdne2934203:0
My screen is shattered otherwise the phone works fine..touch works and screen under glass is good. I want to replace the screen myself but my question is are the screen and digitizer fused (one piece) or can I just replace the glass screen? For an LG power x
Nikki - crwdns2934203:0crwdne2934203:0
Did you ever figure out if there the same or separate. I'm needing to do the same.
sarahelizabeth0526 -
Where do I buy the glass panel?
Liam McBride - crwdns2934203:0crwdne2934203:0
i got the glass screen at amazonbot most digitisers have a ribbon wire to connecttheres doesnt..not sure if its just held on with 2 face tape??
Peter Maggiop - crwdns2934203:0crwdne2934203:0
my screen wont work you cant see anything and touchscreen wont work what glue should i use
King J is a massivegamer - crwdns2934203:0crwdne2934203:0
help i cant answer calls or look at nonifications
i have clean it but is can.t work so now
Rashid king - crwdns2934203:0crwdne2934203:0
Can I use lg power screen to lg leon?
Thanks
M. Jane Alam Khan - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 9
crwdns2942667:0crwdne2942667:0 26,138
