LG Optimus G Pro Rear Facing Camera Replacement
  1. LG Optimus G Pro Rear Facing Camera Replacement, Remove Back Cover.: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Make sure before you begin working on your device, that the device is not charging.
    • Once you have access to the phone, there is a small indent on the bottom left side. Use your fingernail or a plastic opening tool to pry from here and pull off the back casing.
  2. LG Optimus G Pro Rear Facing Camera Replacement, Remove the Battery.: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Once you have properly removed the outer casing, the back should look as so.
    • To remove the battery, pull up from the red mark using your finger. The battery should come up at an angle, and easily be able to be removed.
    • Once the battery is removed you may safely proceed to the next step.
  3. LG Optimus G Pro Rear Facing Camera Replacement, Screw Removal: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG Optimus G Pro Rear Facing Camera Replacement, Screw Removal: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Make sure you remove the battery first. You will see that there are 14 screws on the back of the inner case. Use the Phillips head screwdriver to remove each of the screws, make sure to put the screws in a safe place where they will not get lost.
  4. LG Optimus G Pro Rear Facing Camera Replacement, Remove Cover: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Once you have removed all the screws, you can begin removing the inside cover.
    • Insert the opening tool using a sliding motion into one of the corners and move it along the edges of the inside cover. This will loosen the edges and the inside cover will pry apart from the shell.
  5. LG Optimus G Pro Rear Facing Camera Replacement, Completion: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The inner cover is now removed, you now have access to the many parts on the inside of the phone.
  6. LG Optimus G Pro Rear Facing Camera Replacement, Remove the Ribbon Cable: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a plastic opening tool, pry the connection between the cable and the phone. With even pressure the cable should disconnect from the logic board easily.
  7. LG Optimus G Pro Rear Facing Camera Replacement, Remove the Camera: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • After removing the the Ribbon Cable, the Rear-Facing Camera should be able to be removed easily with your fingers.
crwdns2935229:05crwdne2935229:0
Wesley Pate
crwdns2935283:009/25/14crwdne2935283:0
1,641 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 15-5, Remmell Fall 2014 crwdns2935289:0USF Tampa, Team 15-5, Remmell Fall 2014crwdne2935289:0
USFT-REMMELL-F14S15G5
Question what is the thing with a weird looking number 6 , right above the battery... I broke that and trying to replace it. Also can i replace the LCD only
DENNIS - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 9
crwdns2942667:0crwdne2942667:0 1,955
