LG Grace Charging Port Replacement
  1. LG Grace Charging Port Replacement, Phone Assembly: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Find the indentation along the edge of the phone's back and pry open with your nail. A pry tool may help if you have short nails but shouldn't be necessary.
  2. LG Grace Charging Port Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull the battery out of the back of the phone. A small indent is present to allow you to pry it out but you may also just flip the phone over and strike it gently against your palm.
  3. LG Grace Charging Port Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG Grace Charging Port Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unscrew all of the screws now visible on the back panel of the phone--11 in total. A #00 Phillips screwdriver works here.
    • The screws are M1.3 and 3 mm long.
  4. LG Grace Charging Port Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG Grace Charging Port Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert the Jimmy into the small gap between the edge of the phone screen and body. Gently pry until it pops loose then remove jimmy and use your hands to slowly pry the body away from the screen
  5. LG Grace Charging Port Replacement, Rear Camera: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Locate the pin connection for the camera, noted by red box in the guide photo.
    • Gently lift the camera up while pulling away from connection; it should detach with minimal effort.
  6. LG Grace Charging Port Replacement, Motherboard: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Next we remove the front speaker from the motherboard, with the goal of removing all connections that hold the board in place.
    • The location of the speaker is highlighted in the guide photo.
    • Just like with the camera, gently pull the ribbon wire away from the connector and it should release easily.
  7. LG Grace Charging Port Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • There is also a ribbon cable connected to the board by the charging port, as highlighted in the photo.
    • Pull it away in the same fashion as the others, and now the motherboard should be free.
  8. LG Grace Charging Port Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • From here, you should be able to gently pull the motherboard away from the screen assembly and remove it. I recommend grabbing the edge by the port and lifting with one hand while holding the phone down with the other.
  9. LG Grace Charging Port Replacement, Charging Port: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG Grace Charging Port Replacement, Charging Port: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • With the Motherboard out, it's a quick fix to replace the charging port. Flip the board over to where the solder connection are available to work on.
    • The solder points that you should be working on are easy to identify as flat bits of solder on the back of the board, but they are highlighted in the photo.
    • Heat all the solder joints until the solder melts and then quickly pull the component off of the board. I recommend fully cleaning the solder joints and applying fresh solder when your replace the component.
Dylan Kent
crwdns2935283:009/09/23crwdne2935283:0
679 crwdns2915208:0crwdne2915208:0
University of New Orleans, Team 4-3, McDonald Fall 2023 crwdns2935289:0University of New Orleans, Team 4-3, McDonald Fall 2023crwdne2935289:0
UNO-MCDONALD-F23S4G3
crwdns2942667:0crwdne2942667:0 107
