LG G8 ThinQ Vibration Motor Replacement
  1. LG G8 ThinQ Vibration Motor Replacement, SIM Card Tray: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 LG G8 ThinQ Vibration Motor Replacement, SIM Card Tray: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 LG G8 ThinQ Vibration Motor Replacement, SIM Card Tray: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unplug and power off your phone before you begin.
    • Insert the SIM card eject tool into the pinhole in the lower right side of the phone.
    • Remove the SIM card and tray.
  2. LG G8 ThinQ Vibration Motor Replacement, Back Panel: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 LG G8 ThinQ Vibration Motor Replacement, Back Panel: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 LG G8 ThinQ Vibration Motor Replacement, Back Panel: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Place the phone so that the screen is facing down.
    • Insert opening cards between the back panel and frame of the phone to loosen the clips and adhesive.
    • Using equal pressure, carefully pry the back panel away from the phone.
    • Once enough space has been created, use an opening tool to completely separate the back panel from the phone.
  3. LG G8 ThinQ Vibration Motor Replacement, Midframe: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 LG G8 ThinQ Vibration Motor Replacement, Midframe: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 LG G8 ThinQ Vibration Motor Replacement, Midframe: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove all 14 screws from the midframe using a Phillips #000 screwdriver.
    • Work an opening tool around the perimeter of the midframe to pry and remove it from the phone.
  4. LG G8 ThinQ Vibration Motor Replacement, Speaker System: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 LG G8 ThinQ Vibration Motor Replacement, Speaker System: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 LG G8 ThinQ Vibration Motor Replacement, Speaker System: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using an opening tool, carefully pry out remove the speaker system from the phone.
  5. LG G8 ThinQ Vibration Motor Replacement, Headphone Jack: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 LG G8 ThinQ Vibration Motor Replacement, Headphone Jack: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 LG G8 ThinQ Vibration Motor Replacement, Headphone Jack: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using an opening tool, carefully disconnect the ribbon cable connecting the 3.5mm audio jack to the motherboard.
    • Remove the screw holding the 3.5 mm audio jack in place using a Phillips #000 screwdriver.
    • Remove the audio jack from the phone.
  6. LG G8 ThinQ Vibration Motor Replacement, Battery: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flip phone so that screen is facing up.
    • Using a heating pad, hairdryer, or heat gun, apply heat to loosen the adhesive beneath the battery.
    • Be careful to not overheat the phone; the screen and battery are susceptible to damage.
    • The adhesive can be difficult to soften; it may take many attempts.
  7. LG G8 ThinQ Vibration Motor Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG G8 ThinQ Vibration Motor Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using an opening tool, carefully pry up the ribbon cable to disconnect the battery.
  8. LG G8 ThinQ Vibration Motor Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 LG G8 ThinQ Vibration Motor Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 LG G8 ThinQ Vibration Motor Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using opening cards or an opening tool, carefully pry around the edges of the battery.
    • If you have trouble prying up the battery, the adhesive may not be loose enough. Re-apply heat, or use some isopropyl alcohol under the battery, allowing it to penetrate for several minutes to weaken the adhesive.
    • Remove the battery from the phone.
  9. LG G8 ThinQ Vibration Motor Replacement, Motherboard: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG G8 ThinQ Vibration Motor Replacement, Motherboard: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use an opening tool to disconnect the two coaxial cables from the motherboard.
  10. LG G8 ThinQ Vibration Motor Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 LG G8 ThinQ Vibration Motor Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 LG G8 ThinQ Vibration Motor Replacement: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using an opening tool, carefully disconnect the screen ribbon cable from the motherboard.
    • Using an opening tool, carefully pry up the motherboard from the frame and remove it from the phone.
  11. LG G8 ThinQ Vibration Motor Replacement, Vibration Motor: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG G8 ThinQ Vibration Motor Replacement, Vibration Motor: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the vibration motor from the phone casing using an opening tool.
    • Heat the vibration motor from the other side of the phone to loosen adhesive if needed.
Kristen Gismondi
crwdns2935283:011/12/14crwdne2935283:0
95,852 crwdns2915208:0crwdne2915208:0
crwdns2935297:0255crwdne2935297:0
Staff
crwdns2931471:0119crwdne2931471:0
crwdns2935297:021,572crwdne2935297:0
crwdns2936753:030crwdne2936753:0 7
crwdns2942667:0crwdne2942667:0 468
