LG Front Load Washing Machine Rotor Replacement
crwdns2869540:0crwdne2869540:0: 2,9 B
6
50
218
2.902
crwdns2955950:0crwdne2955950:0: 6
crwdns2960004:06crwdne2960004:0.
crwdns2959984:0crwdne2959984:0: 3
crwdns2959974:03crwdne2959974:0
crwdns2955944:0crwdne2955944:0: 25 - 40 crwdns2931279:0crwdne2931279:0
Use this guide to replace the rotor in your LG front load washing machine.
The rotor is part of the washer's direct drive motor. It doesn't have any electrical components and is less likely to break compared to the motor stator.
This guide will work for most LG front load washing machines. This guide is written with a model WM3050CW washer. If you have a different model, you may encounter some minor disassembly differences, but the overall repair process will be the same.
    1. LG Front Load Washing Machine Rotor Replacement, Safety Precautions: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG Front Load Washing Machine Rotor Replacement, Safety Precautions: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Before you begin your repair, perform the following:
      • Turn off the main water supply
      • Unplug your washer
      • Disconnect all water connections at the rear of your washer
    1. LG Front Load Washing Machine Rotor Replacement, Unfasten the rear panel: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 LG Front Load Washing Machine Rotor Replacement, Unfasten the rear panel: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 LG Front Load Washing Machine Rotor Replacement, Unfasten the rear panel: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Remove the screw(s) securing the rear panel.
    2. LG Front Load Washing Machine Rotor Replacement, Remove the rear panel: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 LG Front Load Washing Machine Rotor Replacement, Remove the rear panel: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 LG Front Load Washing Machine Rotor Replacement, Remove the rear panel: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Unclip the rear panel from the chassis.
    3. LG Front Load Washing Machine Rotor Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the rear panel.
    1. LG Front Load Washing Machine Rotor Replacement, Unfasten the rotor: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG Front Load Washing Machine Rotor Replacement, Unfasten the rotor: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Use an impact driver to remove the 17 mm nut securing the rotor.
      • Alternatively, you can use a wrench and a hammer to loosen the nut.
      • To secure the rotor, you can insert a screwdriver, or a similar tool, between the rotor and the stator. Make sure to brace the tool against one of the screw bosses on the stator.
    2. LG Front Load Washing Machine Rotor Replacement, Remove the rotor: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG Front Load Washing Machine Rotor Replacement, Remove the rotor: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • The rotor is magnetically attracted to the stator.
      • Pull the rotor straight off the stator and drive shaft splines to remove it.
      • Wiggle the rotor as you pull to help disconnect it.
      • This may require significant force.
      • During reassembly, watch your fingers when aligning the rotor over the stator, as the rotor gets sucked in easily.
Repair didn’t go as planned? Ask our Answers community for help.
Bill Gilbert
crwdns2935283:006/30/22crwdne2935283:0
41.012 crwdns2915208:0crwdne2915208:0
crwdns2935297:0261crwdne2935297:0
Staff
crwdns2931471:0120crwdne2931471:0
crwdns2935297:072.955crwdne2935297:0
crwdns2936753:07crwdne2936753:0 50
crwdns2936753:030crwdne2936753:0 218
crwdns2959996:0crwdne2959996:0 2,902
