LG Front Load Washing Machine Inlet Valve Assembly Replacement
    1. LG Front Load Washing Machine Inlet Valve Assembly Replacement, Safety Precautions: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG Front Load Washing Machine Inlet Valve Assembly Replacement, Safety Precautions: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Before you begin your repair, perform the following:
      • Turn off the main water supply
      • Unplug your washer
      • Disconnect all water connections at the rear of your washer
    1. LG Front Load Washing Machine Inlet Valve Assembly Replacement, Unfasten the top panel: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 LG Front Load Washing Machine Inlet Valve Assembly Replacement, Unfasten the top panel: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 LG Front Load Washing Machine Inlet Valve Assembly Replacement, Unfasten the top panel: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Remove the screw(s) securing the top panel brackets to the back panel.
      • You don't need to remove the screws securing the brackets to the top panel.
    2. LG Front Load Washing Machine Inlet Valve Assembly Replacement, Remove the top panel: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG Front Load Washing Machine Inlet Valve Assembly Replacement, Remove the top panel: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Slide the top panel towards the rear of the device to disconnect its clips.
    3. LG Front Load Washing Machine Inlet Valve Assembly Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG Front Load Washing Machine Inlet Valve Assembly Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Tilt the top panel upward to completely disconnect it from the chassis.
      • Remove the top panel.
    1. LG Front Load Washing Machine Inlet Valve Assembly Replacement, Inlet valve information: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 LG Front Load Washing Machine Inlet Valve Assembly Replacement, Inlet valve information: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 LG Front Load Washing Machine Inlet Valve Assembly Replacement, Inlet valve information: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • To prevent confusion, label each valve and its corresponding hose.
      • You can use masking tape or mark the components themselves.
      • Repeat the labelling procedure for each valve and its corresponding connector.
    2. LG Front Load Washing Machine Inlet Valve Assembly Replacement, Disconnect the inlet valve: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 LG Front Load Washing Machine Inlet Valve Assembly Replacement, Disconnect the inlet valve: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 LG Front Load Washing Machine Inlet Valve Assembly Replacement, Disconnect the inlet valve: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Disconnect the connectors from the inlet valve.
      • Always grip cables by their connectors and not the wires themselves.
    3. LG Front Load Washing Machine Inlet Valve Assembly Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Place a dry rag under the inlet valve to soak up any lingering water.
    4. LG Front Load Washing Machine Inlet Valve Assembly Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 LG Front Load Washing Machine Inlet Valve Assembly Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 LG Front Load Washing Machine Inlet Valve Assembly Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Use slip joint pliers to pinch the inlet valve hose clamp and pull it away from the inlet valve assembly.
    5. LG Front Load Washing Machine Inlet Valve Assembly Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG Front Load Washing Machine Inlet Valve Assembly Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Use slip joint pliers to rotate the inlet valve hose back and forth around its connection and loosen it.
    6. LG Front Load Washing Machine Inlet Valve Assembly Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG Front Load Washing Machine Inlet Valve Assembly Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Pull the inlet valve hose straight off its connection on the inlet valve assembly.
    7. LG Front Load Washing Machine Inlet Valve Assembly Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Repeat the previous three steps for each remaining hose attached to the inlet valve assembly.
    8. LG Front Load Washing Machine Inlet Valve Assembly Replacement, Remove the filters: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 LG Front Load Washing Machine Inlet Valve Assembly Replacement, Remove the filters: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 LG Front Load Washing Machine Inlet Valve Assembly Replacement, Remove the filters: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • If your replacement part comes with filters pre-installed, skip this step.
      • Use needle nose pliers to pull the inlet valve filters straight out of the inlets in the chassis.
      • Remove the filters.
    9. LG Front Load Washing Machine Inlet Valve Assembly Replacement, Unfasten the inlet valve assembly: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the screws securing the inlet valve assembly.
    10. LG Front Load Washing Machine Inlet Valve Assembly Replacement, Remove the inlet valve assembly: crwdns2935265:014crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 LG Front Load Washing Machine Inlet Valve Assembly Replacement, Remove the inlet valve assembly: crwdns2935265:014crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 LG Front Load Washing Machine Inlet Valve Assembly Replacement, Remove the inlet valve assembly: crwdns2935265:014crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Pull the inlet valve assembly straight out of its slot in the chassis to remove it.
Repair didn’t go as planned? Ask our Answers community for help.
Bill Gilbert
crwdns2935283:006/30/22crwdne2935283:0
40 168 crwdns2915208:0crwdne2915208:0
crwdns2935297:0261crwdne2935297:0
Staff
crwdns2931471:0123crwdne2931471:0
crwdns2935297:042 765crwdne2935297:0
crwdns2936751:024crwdne2936751:0 12
crwdns2936753:07crwdne2936753:0 72
crwdns2936753:030crwdne2936753:0 265
crwdns2942667:0crwdne2942667:0 6,945
