LG Front Load Washing Machine Drain Hose Replacement
crwdns2869540:0crwdne2869540:0: 38K
34
255
1,242
37,878
crwdns2955950:0crwdne2955950:0: 16
crwdns2960004:04crwdne2960004:0, crwdns2960008:012crwdne2960008:0
crwdns2959984:0crwdne2959984:0: 3
crwdns2959974:03crwdne2959974:0
crwdns2955944:0crwdne2955944:0: 30 - 45 crwdns2931279:0crwdne2931279:0
crwdns2862627:0crwdne2862627:0
crwdns2862628:0crwdne2862628:0
Use this guide to remove and replace the drain hose in your LG front load washing machine.
The drain hose channels wastewater out of the washer. It's a single piece of hose that's connected to the drain pump inside the washer. To replace it, you'll have to access the washer internals.
This guide will work for most LG front load washing machines. This guide is written with a model WM3050CW washer. If you have a different model, you may encounter some minor disassembly differences, but the overall repair process will be the same.
The metal ring holding the rubber boot can be difficult to reinstall. You can buy this tool to make the reinstallation easier, or ask additional people to help.
    1. LG Front Load Washing Machine Drain Hose Replacement, Safety Precautions: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG Front Load Washing Machine Drain Hose Replacement, Safety Precautions: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Before you begin your repair, perform the following:
      • Turn off the main water supply
      • Unplug your washer
      • Disconnect all water connections at the rear of your washer
    1. LG Front Load Washing Machine Drain Hose Replacement, Unfasten the top panel: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 LG Front Load Washing Machine Drain Hose Replacement, Unfasten the top panel: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 LG Front Load Washing Machine Drain Hose Replacement, Unfasten the top panel: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Remove the screw(s) securing the top panel brackets to the back panel.
      • You don't need to remove the screws securing the brackets to the top panel.
    2. LG Front Load Washing Machine Drain Hose Replacement, Remove the top panel: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG Front Load Washing Machine Drain Hose Replacement, Remove the top panel: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Slide the top panel towards the rear of the device to disconnect its clips.
    3. LG Front Load Washing Machine Drain Hose Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG Front Load Washing Machine Drain Hose Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Tilt the top panel upward to completely disconnect it from the chassis.
      • Remove the top panel.
    1. LG Front Load Washing Machine Drain Hose Replacement, Remove the detergent drawer: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG Front Load Washing Machine Drain Hose Replacement, Remove the detergent drawer: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Pull the detergent drawer away from the chassis as far as it will go.
    2. LG Front Load Washing Machine Drain Hose Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 LG Front Load Washing Machine Drain Hose Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 LG Front Load Washing Machine Drain Hose Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Press down on the "Push" button to disengage the clips securing the detergent drawer.
      • Pull the drawer out of its slot on the chassis and remove it.
    1. LG Front Load Washing Machine Drain Hose Replacement, Disconnect the control panel: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 LG Front Load Washing Machine Drain Hose Replacement, Disconnect the control panel: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 LG Front Load Washing Machine Drain Hose Replacement, Disconnect the control panel: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Disconnect the connectors attached to the control panel.
      • Always grip cables by their connectors and not the wires themselves.
    2. LG Front Load Washing Machine Drain Hose Replacement, Unfasten the control panel: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG Front Load Washing Machine Drain Hose Replacement, Unfasten the control panel: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Remove the screw(s) securing the control panel to the top edge of the chassis.
    3. LG Front Load Washing Machine Drain Hose Replacement, Unfasten the detergent dispenser: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the screw(s) securing the detergent dispenser.
    4. LG Front Load Washing Machine Drain Hose Replacement, Unclip the control panel: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 LG Front Load Washing Machine Drain Hose Replacement, Unclip the control panel: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 LG Front Load Washing Machine Drain Hose Replacement, Unclip the control panel: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Use a flathead screwdriver, or a pry tool, to unclip the control panel from the chassis.
    5. LG Front Load Washing Machine Drain Hose Replacement, Remove the control panel: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 LG Front Load Washing Machine Drain Hose Replacement, Remove the control panel: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 LG Front Load Washing Machine Drain Hose Replacement, Remove the control panel: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Remove the control panel, making sure to thread any cables through the chassis.
    1. LG Front Load Washing Machine Drain Hose Replacement, Open the door: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG Front Load Washing Machine Drain Hose Replacement, Open the door: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Open the front door completely.
    2. LG Front Load Washing Machine Drain Hose Replacement, Remove the boot ring: crwdns2935265:013crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 LG Front Load Washing Machine Drain Hose Replacement, Remove the boot ring: crwdns2935265:013crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 LG Front Load Washing Machine Drain Hose Replacement, Remove the boot ring: crwdns2935265:013crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Use needle nose pliers to grip the spring end of the metal ring at the bottom of the rubber boot.
      • Pull the ring away from the chassis to separate it from the boot.
    3. LG Front Load Washing Machine Drain Hose Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 LG Front Load Washing Machine Drain Hose Replacement: crwdns2935265:014crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 LG Front Load Washing Machine Drain Hose Replacement: crwdns2935265:014crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Use your hand to completely pull the ring off the boot.
      • During reassembly, perform the following:
      • Insert one end of the ring into its groove along the boot's perimeter.
      • Use pliers to slowly stretch the ring around the boot's perimeter until it's completely nested in its groove.
      • Be sure the spring is centered at the bottom of the boot when you reinstall it.
      • This procedure will take significant force.
    4. LG Front Load Washing Machine Drain Hose Replacement, Disconnect the boot: crwdns2935265:015crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 LG Front Load Washing Machine Drain Hose Replacement, Disconnect the boot: crwdns2935265:015crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 LG Front Load Washing Machine Drain Hose Replacement, Disconnect the boot: crwdns2935265:015crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Use your fingers to pull the boot off its lip on the front panel.
    5. LG Front Load Washing Machine Drain Hose Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 LG Front Load Washing Machine Drain Hose Replacement: crwdns2935265:016crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 LG Front Load Washing Machine Drain Hose Replacement: crwdns2935265:016crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Slide your fingers around the lip of the boot until it's completely separated from the panel.
    6. LG Front Load Washing Machine Drain Hose Replacement, Remove the filter panel: crwdns2935265:017crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 LG Front Load Washing Machine Drain Hose Replacement, Remove the filter panel: crwdns2935265:017crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 LG Front Load Washing Machine Drain Hose Replacement, Remove the filter panel: crwdns2935265:017crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Open the filter panel at the bottom of the front panel.
      • Unclip the filter panel.
    7. LG Front Load Washing Machine Drain Hose Replacement, Drain the machine: crwdns2935265:018crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 LG Front Load Washing Machine Drain Hose Replacement, Drain the machine: crwdns2935265:018crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 LG Front Load Washing Machine Drain Hose Replacement, Drain the machine: crwdns2935265:018crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Generally, you should drain your machine when you are repairing the pumps or any hoses leading to or from them.
      • Place a bowl next to the machine.
      • Pull the drain filter hose out of its slot in the chassis enough to lay over the bowl.
      • Remove the plug at the end of the drain filter hose to release excess water into the bowl.
      • During reassembly, re-plug the drain filter hose and thread it back through its slot in the chassis.
    8. LG Front Load Washing Machine Drain Hose Replacement, Unfasten the filter trim: crwdns2935265:019crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the screw(s) securing the filter trim.
    9. LG Front Load Washing Machine Drain Hose Replacement, Remove the filter trim: crwdns2935265:020crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG Front Load Washing Machine Drain Hose Replacement, Remove the filter trim: crwdns2935265:020crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Pull the filter trim straight off the front panel to remove it.
    10. LG Front Load Washing Machine Drain Hose Replacement, Unfasten the lower front panel: crwdns2935265:021crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the screw(s) securing the lower front panel.
    11. LG Front Load Washing Machine Drain Hose Replacement, Unfasten the door latch: crwdns2935265:022crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the screw(s) securing the door latch.
    12. LG Front Load Washing Machine Drain Hose Replacement, Remove the door latch: crwdns2935265:023crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 LG Front Load Washing Machine Drain Hose Replacement, Remove the door latch: crwdns2935265:023crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 LG Front Load Washing Machine Drain Hose Replacement, Remove the door latch: crwdns2935265:023crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Pull the door latch through its slot in the chassis and let it hang on its wire.
    13. LG Front Load Washing Machine Drain Hose Replacement, Unfasten the front panel: crwdns2935265:024crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 LG Front Load Washing Machine Drain Hose Replacement, Unfasten the front panel: crwdns2935265:024crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 LG Front Load Washing Machine Drain Hose Replacement, Unfasten the front panel: crwdns2935265:024crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Hold the front panel against the chassis while performing this step to prevent it from falling.
      • Remove the screw(s) securing the front panel.
    14. LG Front Load Washing Machine Drain Hose Replacement, Remove the front panel: crwdns2935265:025crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 LG Front Load Washing Machine Drain Hose Replacement, Remove the front panel: crwdns2935265:025crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 LG Front Load Washing Machine Drain Hose Replacement, Remove the front panel: crwdns2935265:025crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Lift the front panel upward to separate it from its clips on the bottom of the chassis.
      • Pull the front panel away from the chassis to completely separate the front panel.
    15. LG Front Load Washing Machine Drain Hose Replacement: crwdns2935265:026crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the front panel.
    1. LG Front Load Washing Machine Drain Hose Replacement, Unfasten the rear panel: crwdns2935265:027crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 LG Front Load Washing Machine Drain Hose Replacement, Unfasten the rear panel: crwdns2935265:027crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 LG Front Load Washing Machine Drain Hose Replacement, Unfasten the rear panel: crwdns2935265:027crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Remove the screw(s) securing the rear panel.
    2. LG Front Load Washing Machine Drain Hose Replacement, Remove the rear panel: crwdns2935265:028crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 LG Front Load Washing Machine Drain Hose Replacement, Remove the rear panel: crwdns2935265:028crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 LG Front Load Washing Machine Drain Hose Replacement, Remove the rear panel: crwdns2935265:028crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Unclip the rear panel from the chassis.
    3. LG Front Load Washing Machine Drain Hose Replacement: crwdns2935265:029crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the rear panel.
    1. LG Front Load Washing Machine Drain Hose Replacement, Disconnect the drain hose: crwdns2935265:030crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 LG Front Load Washing Machine Drain Hose Replacement, Disconnect the drain hose: crwdns2935265:030crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 LG Front Load Washing Machine Drain Hose Replacement, Disconnect the drain hose: crwdns2935265:030crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Use slip joint pliers to pinch the drain hose clamp and slide it up the hose away from the pump assembly.
    2. LG Front Load Washing Machine Drain Hose Replacement: crwdns2935265:031crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 LG Front Load Washing Machine Drain Hose Replacement: crwdns2935265:031crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 LG Front Load Washing Machine Drain Hose Replacement: crwdns2935265:031crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Use slip joint pliers to rotate the drain hose back and forth around its connection and loosen it.
      • Pull the drain hose straight off its connection on the assembly.
    3. LG Front Load Washing Machine Drain Hose Replacement, Unclip the drain hose: crwdns2935265:032crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 LG Front Load Washing Machine Drain Hose Replacement, Unclip the drain hose: crwdns2935265:032crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 LG Front Load Washing Machine Drain Hose Replacement, Unclip the drain hose: crwdns2935265:032crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Depending on your device, your drain hose could be clipped to different sides of the chassis.
      • While holding the back of clip with one hand, use the other to push the prongs of the clip and release them.
      • Repeat for each prong until the clip slides through the chassis.
    4. LG Front Load Washing Machine Drain Hose Replacement, Reposition the drain hose: crwdns2935265:033crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Reposition the drain hose so you can access the plastic clip.
    5. LG Front Load Washing Machine Drain Hose Replacement, Unfasten the drain hose: crwdns2935265:034crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the screw(s) securing the drain hose.
    6. LG Front Load Washing Machine Drain Hose Replacement, Apply the tape: crwdns2935265:035crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • To prevent confusion during reassembly, apply some masking tape where the plastic clip is located.
    7. LG Front Load Washing Machine Drain Hose Replacement, Remove the plastic clip: crwdns2935265:036crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 LG Front Load Washing Machine Drain Hose Replacement, Remove the plastic clip: crwdns2935265:036crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 LG Front Load Washing Machine Drain Hose Replacement, Remove the plastic clip: crwdns2935265:036crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Pull the plastic clip off the drain hose.
      • Remove the plastic clip.
    8. LG Front Load Washing Machine Drain Hose Replacement, Remove the drain hose: crwdns2935265:037crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG Front Load Washing Machine Drain Hose Replacement, Remove the drain hose: crwdns2935265:037crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Pull the drain hose through its slot in the chassis.
    9. LG Front Load Washing Machine Drain Hose Replacement: crwdns2935265:038crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 LG Front Load Washing Machine Drain Hose Replacement: crwdns2935265:038crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 LG Front Load Washing Machine Drain Hose Replacement: crwdns2935265:038crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Remove the drain hose.
Repair didn’t go as planned? Ask our Answers community for help.
Bill Gilbert
crwdns2935283:006/30/22crwdne2935283:0
41,012 crwdns2915208:0crwdne2915208:0
crwdns2935297:0261crwdne2935297:0
Staff
crwdns2931471:0120crwdne2931471:0
crwdns2935297:072,955crwdne2935297:0
crwdns2947412:012crwdne2947412:0
My washer still has water in can I start from step 26, to get the drain hose out?
Tan - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Hello! You need the water out, but you can try to drain it by lowering the drain hose to floor level with a pan or shallow bowl to catch water from the end of it. If your drain hose is the problem (like it is plugged or kinked), this probably won't work. A fast but messy way to drain the washer is to remove the coin trap/filter basket located at the front of the machine (see step 18 the large round black cap is what you remove). Have a lot of towels on hand to absorb the water. If you want to you can use the small drain hose that is next to the filter. Have a bowl or container on hand to catch the water. pull the small plug out from the end of the little hose and water will start draining. It will be slow but a lot less messy.
Bill Gilbert - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
I just added a step to show how to drain the machine (it is a new Step 18 in the guide)
Is there a check valve located inside this hose?
Kerri V - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
I just need to check the drain hose for a clog. Is there a way to disconnect the drain hose without disassembling the machine so much? or, can I disconnect the drain hose after removing the rear panel?
Ryan D Whitaker - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936751:024crwdne2936751:0 34
crwdns2936753:07crwdne2936753:0 255
crwdns2936753:030crwdne2936753:0 1,242
crwdns2959996:0crwdne2959996:0 37,878
