LG Front Load Washing Machine Detergent Dispenser Replacement
  1. LG Front Load Washing Machine Detergent Dispenser Replacement, Safety Precautions: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG Front Load Washing Machine Detergent Dispenser Replacement, Safety Precautions: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Before you begin your repair, perform the following:
    • Turn off the main water supply
    • Unplug your washer
    • Disconnect all water connections at the rear of your washer
  2. LG Front Load Washing Machine Detergent Dispenser Replacement, Unfasten the top panel: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 LG Front Load Washing Machine Detergent Dispenser Replacement, Unfasten the top panel: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 LG Front Load Washing Machine Detergent Dispenser Replacement, Unfasten the top panel: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the screw(s) securing the top panel brackets to the back panel.
    • You don't need to remove the screws securing the brackets to the top panel.
  3. LG Front Load Washing Machine Detergent Dispenser Replacement, Remove the top panel: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG Front Load Washing Machine Detergent Dispenser Replacement, Remove the top panel: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide the top panel towards the rear of the device to disconnect its clips.
  4. LG Front Load Washing Machine Detergent Dispenser Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG Front Load Washing Machine Detergent Dispenser Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Tilt the top panel upward to completely disconnect it from the chassis.
    • Remove the top panel.
  5. LG Front Load Washing Machine Detergent Dispenser Replacement, Remove the detergent drawer: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG Front Load Washing Machine Detergent Dispenser Replacement, Remove the detergent drawer: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull the detergent drawer away from the chassis as far as it will go.
  6. LG Front Load Washing Machine Detergent Dispenser Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 LG Front Load Washing Machine Detergent Dispenser Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 LG Front Load Washing Machine Detergent Dispenser Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Press down on the "Push" button to disengage the clips securing the detergent drawer.
    • Pull the drawer out of its slot on the chassis and remove it.
  7. LG Front Load Washing Machine Detergent Dispenser Replacement, Disconnect the control panel: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 LG Front Load Washing Machine Detergent Dispenser Replacement, Disconnect the control panel: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 LG Front Load Washing Machine Detergent Dispenser Replacement, Disconnect the control panel: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Disconnect the connectors attached to the control panel.
    • Always grip cables by their connectors and not the wires themselves.
  8. LG Front Load Washing Machine Detergent Dispenser Replacement, Unclip the control panel cable: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 LG Front Load Washing Machine Detergent Dispenser Replacement, Unclip the control panel cable: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 LG Front Load Washing Machine Detergent Dispenser Replacement, Unclip the control panel cable: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unclip any connections the control panel cable has to the chassis or other components.
  9. LG Front Load Washing Machine Detergent Dispenser Replacement, Detergent dispenser hose information: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • To prevent confusion, label each detergent hose and its corresponding dispenser connection.
    • You can use masking tape or mark the components themselves.
  10. LG Front Load Washing Machine Detergent Dispenser Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG Front Load Washing Machine Detergent Dispenser Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use slip joint pliers to pinch the detergent dispenser hose clamp and pull it away from the assembly.
  11. LG Front Load Washing Machine Detergent Dispenser Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG Front Load Washing Machine Detergent Dispenser Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use slip joint pliers to gently rotate the detergent dispenser hose back and forth around its connection and loosen it.
  12. LG Front Load Washing Machine Detergent Dispenser Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG Front Load Washing Machine Detergent Dispenser Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull the detergent dispenser hose straight off its connection on the assembly.
    • Repeat the loosening and removal procedure for each hose.
  13. LG Front Load Washing Machine Detergent Dispenser Replacement, Disconnect the dispenser: crwdns2935265:013crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 LG Front Load Washing Machine Detergent Dispenser Replacement, Disconnect the dispenser: crwdns2935265:013crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 LG Front Load Washing Machine Detergent Dispenser Replacement, Disconnect the dispenser: crwdns2935265:013crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Loosen any fasteners securing the bellows to the detergent dispenser.
    • Pull the bellows straight off its connection on the dispenser to disconnect it.
  14. LG Front Load Washing Machine Detergent Dispenser Replacement, Unfasten the detergent dispenser: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the screw(s) securing the detergent dispenser.
  15. LG Front Load Washing Machine Detergent Dispenser Replacement, Unclip the detergent dispenser: crwdns2935265:015crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 LG Front Load Washing Machine Detergent Dispenser Replacement, Unclip the detergent dispenser: crwdns2935265:015crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 LG Front Load Washing Machine Detergent Dispenser Replacement, Unclip the detergent dispenser: crwdns2935265:015crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide the detergent dispenser out of its slot in the chassis to unclip it.
    • Completely separate the dispenser from the chassis.
  16. LG Front Load Washing Machine Detergent Dispenser Replacement, Remove the detergent dispenser: crwdns2935265:016crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the detergent dispenser.
Repair didn’t go as planned? Ask our Answers community for help.
Bill Gilbert
crwdns2935283:006/30/22crwdne2935283:0
37,987 crwdns2915208:0crwdne2915208:0
crwdns2935297:0261crwdne2935297:0
Staff
crwdns2931471:0118crwdne2931471:0
crwdns2935297:022,412crwdne2935297:0
crwdns2936753:030crwdne2936753:0 52
crwdns2942667:0crwdne2942667:0 1,676
