LG Chocolate 3 Display Connector Replacement
  1. LG Chocolate 3 Display Connector Replacement, Display Connector: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the battery and expose the motherboard following the General Disassembly LG VX8560. Keep in mind that you will need to reinstall the side keys after completing this repair.
    • Next, locate the intertwined blue and red wire; this is the display connector that links the screen to the motherboard.
  2. LG Chocolate 3 Display Connector Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Skip this step if the screen display connector is already detached from the motherboard. Using a spudger, insert the pointed end between the plastic end of the wire and the motherboard socket, then carefully lift or push the wire to disconnect it. You should see two golden pins protruding from the plastic connector.
    • To reconnect, align the two golden pins with their corresponding socket on the motherboard and gently press down until you hear a click indicating a secure connection.
    • To reassemble your device, follow the Side Keys Installation guide in reverse order.
Mitchel
crwdns2935283:004/18/13crwdne2935283:0
1 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 13-62, Johann Spring 2013 crwdns2935289:0Cal Poly, Team 13-62, Johann Spring 2013crwdne2935289:0
CPSU-JOHANN-S13S13G62
crwdns2936753:030crwdne2936753:0 3
crwdns2942667:0crwdne2942667:0 384
