The guide was develop to help replace the screen of a LG Aristo, also known as LGMS210 or MS210.
Turn off the device and make sure you are working on a flat, lit surface.
Use an iFixit opening tool to pry off the back case.
Remove the SD and SIM cards by sliding the cards out with your finger.
Remove the battery by prying it up with a fingernail or opening tool from the bottom edge.
Remove the ten screws from the midframe with a Phillips #000 screwdriver.
Pry up on the screen with a plastic opening tool.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Detach the cables from the press fit connectors.
You can lift them up with you finger or you can use tweezers (optional).
To reassemble your device, follow these instructions in reverse order. I hope that these steps have helped you with your issue.
Do i need Loca Glue to replace the outer Glass?
