LG 55UH6150 backlight LED replacement
edsgarage1
crwdns2944107:0crwdnd2944107:0edsgarage1crwdnd2944107:0crwdnd2944107:0crwdnd2944107:03crwdnd2944107:0crwdne2944107:0
crwdns2944111:0Mha 30, 2024crwdne2944111:0
2 - 3 crwdns2931253:0crwdne2931253:0
crwdns2937801:0crwdne2937801:0
crwdns2944444:0crwdne2944444:0
crwdns2942287:0crwdne2942287:0
One half (right) side of my LG55UH6150 was dark, black actually. This unit was given to me by my work. It was used as a computer monitor on the shop floor. From what I heard it was installed in late 2016 early 2017 and never turned off. If my math is right that’s about 35,040 hours. The LED’s have an advertised life of 30,000 hours so that seems right. The first thing I needed to do was 1) verify that it was indeed the LED strip that was bad and 2) see if replacements were available. I removed the back of the set which was pretty straight forward. I found the plug that powered the LED strips and checked for voltages to both. YES I have voltage going to the strips but only one side was lit. Next thing was to determine what type of LED strips were used. A quick google search, actually a 3 hour google search (darn youtube) I was able to determine that the two strips used were 6916L2318A and 6916L2319A both have 60 LED’s per strip.
crwdns2944105:0crwdne2944105:0
  1. LG 55UH6150 backlight LED replacement, Remove back cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 LG 55UH6150 backlight LED replacement, Remove back cover: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 LG 55UH6150 backlight LED replacement, Remove back cover: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Back of set after rear cover removed. Bottom of TV at bottom of photo. The two speakers were removed by pulling up after disconnecting plug. Next is to remove the lower black panel that houses the power button and speaker mounts.
  2. LG 55UH6150 backlight LED replacement, Remove lower speaker bracket and power button: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG 55UH6150 backlight LED replacement, Remove lower speaker bracket and power button: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • A few screws on the bottom and two plugs disconnected and the black bottom panel is removed. Now you can disconnect the display power connectors. There are 2 long green circuit boards (LCD drivers)strips at the bottom.
  3. LG 55UH6150 backlight LED replacement, Disconnect the display cable: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Close up of the display connector disconnected. Typical flip back the black bar and remove the ribbon cable,
  4. LG 55UH6150 backlight LED replacement, Remove bezel and plastic frame: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The next step has no photo but involves removing the screws from around the metal bezel. Make sure you get them all.
  5. LG 55UH6150 backlight LED replacement, Secure PCB and cable to front of display: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Now you'll need to remove the plastic frame that holds the display and filters in place. A series of "snaps" need to be un-clipped . Carefully fold over the printed circuit boards and cables and tape them to the front of the display. This part is tricky as you'll need to stand up the display carefully without having the filters fall out.
    I have the exact same TV and needed to do the exact same repair. I decided to take a different route starting at this step. After removing the metal bezel I set the TV face down again. First, I laid the circuit boards and cables out flat instead of taping them to the screen. Using spudgers I unclipped the black frame from the metal back. At the corners two spudgers and or picks and a very small screwdriver were used to pull the metal corner out of the plastic frame. Do not insert the screwdriver into any frame holes. At the corners have 4 of the metal surround screws at the ready and put one in the metal back at each corner to keep it from falling back down and re-clipping. Read my next comment after you have the back all unclipped.
    Bruce Hart - crwdns2934203:0crwdne2934203:0
  6. LG 55UH6150 backlight LED replacement, Tape screen and filters together.  KEEP THEM SAFE: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG 55UH6150 backlight LED replacement, Tape screen and filters together.  KEEP THEM SAFE: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Tape all the filters and diffuser together. You don't want them falling out. By now I hope your putting all the pieces in a safe place. We will need to reassemble them, (I hope.) I marked them "B" for bottom.
    I then put long 6MM bolts partway into the "VESA" mounting holes on the metal back and used them as "pull knobs" to pull the back up and off of the screen/bezel/diffusers. I had a helper for this part. Go slowly as there is some suction generated from pulling the back up and off of the screen parts. If you just yank it up you will cause the rear most layers to shift around a little bit. After you pull the back up you will see what it picured in Step 7. This method leaves the screen fully suppported and virtually eliminates the chance of breakage. Next comment for reassembly tips.
  7. LG 55UH6150 backlight LED replacement, LED's exposed: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 LG 55UH6150 backlight LED replacement, LED's exposed: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 LG 55UH6150 backlight LED replacement, LED's exposed: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Here we can finally see the LED strips attached to the bottom of the frame. You can see the connectors. You can disconnect these now as we will attempt to remove them. They are held in place with thin, double-sided tape.
  8. LG 55UH6150 backlight LED replacement, Remove LED strip: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • I started the removal process by inserting a thin metal tool between the strip and the frame. The tape came loose from the frame and stayed on the strip. I moved the tool down the length, prying very lightly. We'll be replacing these but I wanted to do the least amount of damage to them . I still need to read the part number off of them.
  9. LG 55UH6150 backlight LED replacement, The LED strips are out!!: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 LG 55UH6150 backlight LED replacement, The LED strips are out!!: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 LG 55UH6150 backlight LED replacement, The LED strips are out!!: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • As you can clearly see, LEDs 2 and 4 on the bottom strip are burnt out. I verified this with a magnifying glass. This strip was from the right side that went dark. Next step is to order strips 6916L2318A and 6916L2319A and replace them and put this TV back together.
  10. LG 55UH6150 backlight LED replacement, Re-assemble with new LED strips: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 LG 55UH6150 backlight LED replacement, Re-assemble with new LED strips: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 LG 55UH6150 backlight LED replacement, Re-assemble with new LED strips: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The new LED strips came in today and I started to re-assemble the display. Thanks "shopjimmy.com" for having the strips and keeping me away from the Chinese ones on e-bay. The two strips cost me $63.00 total. They arrived in good shape.
  11. LG 55UH6150 backlight LED replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 LG 55UH6150 backlight LED replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 LG 55UH6150 backlight LED replacement: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The tools I used and the strips ready for installation. The fine people at LG make it fool proof to insert the new strips by putting a cutout in the strip and a tab in the frame. REMEMBER to test fit the plug into the connector. One side of my LED had misaligned pin that I had to straighten to get the plug to fit. Very difficult to do in frame.
  12. LG 55UH6150 backlight LED replacement, Attaching the LED's to the frame: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 LG 55UH6150 backlight LED replacement, Attaching the LED's to the frame: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 LG 55UH6150 backlight LED replacement, Attaching the LED's to the frame: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Carefully peal the backing off of the strip and lay it in the position over the tabs. Make sure you keep the sticky side away from the frame for now. When the strip is lined up where it needs to be, carefully push it into position into the frame. This tape is not forgiving so make sure it perfectly straight and flat to the frame, top and bottom
    After replacing the LED strips (and make sure you replace both- my new ones were a slightly different color temperature than the one good LED strip that was in the TV; if I had not replaced both the color balance would be terrible and would make the TV virtually unwatchable. To test the LED strips before assembly you can reattach the power button assembly and put power to the TV (remember it's an open cirucit board, do not touch them when connected). The remote should then turn the TV on without the display in place. You won't hurt anything and be aware that the LED strips are VERY bright.
  13. LG 55UH6150 backlight LED replacement, Replace the filters and reflectors: crwdns2935265:013crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 LG 55UH6150 backlight LED replacement, Replace the filters and reflectors: crwdns2935265:013crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 LG 55UH6150 backlight LED replacement, Replace the filters and reflectors: crwdns2935265:013crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Snap in the black plastic frame. Again the fine people at LG helped with tabs on the frame and slots on the filters. You can't install them upside down. Carefully align the tabs with the slots and make sure they are flat and centered into the frame. You really can't mess this part up unless to forgot to tape them together when disassembling.
    bonjour
    en remontant mon téléviseur je m aperçois que la luminosité est bonne en bas mais plus sombre en haut
    y a t-il un ordre pour mettre les filtres ma fille les à déplacer et les as pas remis dans l ordre.
    merci de votre réponse.
    Yoan Dulas - crwdns2934203:0crwdne2934203:0
    Here's the part where you put the metal rear section with the new LED strips back on the plastic bezel. Remove the 4 small screws that are holding the metal back and then gently push it into place and snap the bezel around the metal back. Some painters tape on the corners and in the middle of the top and bottom of the screen will hold it in place (with your help) as you then turn the TV over onto its back for installation of the metal frame. After that, carefully put it back on its screen (on something soft as always) and finish assembly of the back.
  14. LG 55UH6150 backlight LED replacement, Replace the filters and black plastic frame: crwdns2935265:014crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 LG 55UH6150 backlight LED replacement, Replace the filters and black plastic frame: crwdns2935265:014crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 LG 55UH6150 backlight LED replacement, Replace the filters and black plastic frame: crwdns2935265:014crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Once the filters are in place, make sure the filters are flat and the snaps secure. Now comes the trickery park. Replacing the glass display panel. If this goes wrong forget about this TV. A new display cost's $560.00! Lay the display into the frame CENTERED. If you find it's off center DO NOT LIFT ONLY ONE CORNER lift along the whole side.
  15. LG 55UH6150 backlight LED replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 LG 55UH6150 backlight LED replacement: crwdns2935265:015crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 LG 55UH6150 backlight LED replacement: crwdns2935265:015crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • If you made it this far, congratulations the hard part is done. From now on remember the display now has it's glass panel in place. Be careful if leaning over the display. Un-tape the PCB from the glass and fold them under the frame. The next step is to install the metal bezel that holds the glass panel in place. Easy does it from now on.
  16. LG 55UH6150 backlight LED replacement, Attach the display PCB cables: crwdns2935265:016crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 LG 55UH6150 backlight LED replacement, Attach the display PCB cables: crwdns2935265:016crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 LG 55UH6150 backlight LED replacement, Attach the display PCB cables: crwdns2935265:016crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The display PCB fit under a raised tab on the frame. Slide the PCB into place and attach the ribbon cables. The stiffness of the cables make it easy to get them into the connector. They kinda just want to jump in. Snap the hinge over to secure. Repeat on the other side. I kept the screws in plastic bags with labels.
  17. LG 55UH6150 backlight LED replacement, Plug in power connector and speakers: crwdns2935265:017crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 LG 55UH6150 backlight LED replacement, Plug in power connector and speakers: crwdns2935265:017crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 LG 55UH6150 backlight LED replacement, Plug in power connector and speakers: crwdns2935265:017crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Now we install the bottom black panel that holds the power button and speakers. This photo shows the tab in the center that fits into a cutout in the frame. Slide the assembly into place and attach with 3 screws. Plug in any other connectors you may have disconnected. Check carefully, the back is going on soon and we do want this to work.
  18. LG 55UH6150 backlight LED replacement, Replace the speakers: crwdns2935265:018crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 LG 55UH6150 backlight LED replacement, Replace the speakers: crwdns2935265:018crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 LG 55UH6150 backlight LED replacement, Replace the speakers: crwdns2935265:018crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The speakers are held into place with a tab at the top and 2 rubber pins in the back. Slide the tab into the slot and GENTLY push in the speakers, remember the glass display is in! Plug in the 2 connectors.
  19. LG 55UH6150 backlight LED replacement, Finished panel ready for test: crwdns2935265:019crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Here is the finished panel ready for testing. I kept the back off for now until I power up the unit. No telling if I forgot a cable. I stood the set up and put a couple of folded rags under each corner to hold it up off the floor so I can operate the power button. Now plug in the power cord and turn on the power.
  20. LG 55UH6150 backlight LED replacement, WOW we have a picture on BOTH sides.: crwdns2935265:020crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 LG 55UH6150 backlight LED replacement, WOW we have a picture on BOTH sides.: crwdns2935265:020crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 LG 55UH6150 backlight LED replacement, WOW we have a picture on BOTH sides.: crwdns2935265:020crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Hopefully you will see a well lit, beautiful picture like this. If you don't, check the power cord and connections at the display ribbon cable. Enjoy the TV YOU fixed. This has been a fun and rewarding project. Truth is, this set is too big for my living room. I can't use it, it was truly a labor of love. I'll leave it in the basement for now.
    Wasn't sure if I wanted to tackle this job, but it now seems [just barely] within my skillset. I really liked that he warned us of the minefields! Ordered a toolkit and that plastic pry tool. Now off to the site he listed for the LED strips.
    Stanley Foss - crwdns2934203:0crwdne2934203:0
Document the disassembly with as many photos and notes as you can. It’s easy to get caught up in the process and forget. It’s best to have all the parts needed before you start so you can start and finish in a timely manner.
crwdns2935229:015crwdne2935229:0
crwdns2947821:0crwdne2947821:0
crwdns2947823:0crwdne2947823:0
edsgarage1
crwdns2935283:012/01/13crwdne2935283:0
1.052 crwdns2915208:0crwdne2915208:0
crwdns2947412:015crwdne2947412:0
I’m a technician but not a tv tech, it took me 30 minutes to get the LED board out and now I’m waiting on the new boards to arrive. This was a great guide! I don’t know if I would have done it on my own without breaking something. My TV was a little over 3 years old and like the guide, there was 2 led’s that popped. I tested everything else and all looks good, the LED driver on the power supply looks to be ok. Thank you for putting up this guide!
drgadget009 - crwdns2934203:0crwdne2934203:0
Where can I buy the backlight for 55UH6150-PB and is there a difference between 55UH6150-PB and 55UH6150-CB?
Aj's Vlog - crwdns2934203:0crwdne2934203:0
I would have no idea where to get those parts. Try google?
edsgarage1 -
great guide and propably I’ll use it pretty soon.
for LG 55UH615T model I found that these strips should work:
https://www.aliexpress.com/item/10050027...
cheers!
Piotr Zyla - crwdns2934203:0crwdne2934203:0
Where can I buy a backlight unit for a LG TV model 65LA9700?
Michael - crwdns2934203:0crwdne2934203:0
You can do an online search by either your TV’s model number but preferably you use the LCD panel number. It should be on a sticker on the panel. Remove the TV’s back cover to find it.
oldturkey03 -
I have an 55uh850v. After disassembly of my tv i found that the diffuser plate (2,6 mm thick) has a crack of 10cm in it at the bottom. With the tv on, this crack gives more light through the display.
Where can i buy a replacement for this diffuser plate/sheet?
Lau - crwdns2934203:0crwdne2934203:0
I have no idea if you can get the diffuser anywhere. I’d do a google search OR keep an eye out for a trashed tv at the curb. Good luck.
edsgarage1 -
Hi,
Thanks for the nice tutorial. I was sucesfull in replacing the LEDs. However I got a small whitish spot( 3cm diameter) close to the center of the screen. It looks like some light is bleeding through the panel and it is visible only on dark backgrounds. Any ideea of what i did wrong?
Alexandru Simion - crwdns2934203:0crwdne2934203:0
How did you lift the screen without breaking it?
Lana Duffey - crwdns2934203:0crwdne2934203:0
I slid the display to allow me to lift up on the long edge. Once you get it up a bit, it will come up.
edsgarage1 -
I want to thank the author of this guide, it's well thought out, and explicit enough for those with the skills to pull off this repair. It's certainly not for beginners.
Just to add my own notes, I used an Xacto knife to remove the adhesive on the old LED strips, if you're careful it is quite easy.
Secondly, I would recommend that everyone use gloves when dealing with the LCD panel. I made the mistake of working barehanded, and after putting it all back together, I noticed some minor fingerprints at the edges, on the inner side of the LCD panel. Not enough to make me want to take it all off and clean it, but enough to know that gloves are going to be a must in the future.
Last but not least, the time estimate is accurate, took me just about 2.5 hours from the time I took the TV down to the time I put it back up.
Thanks again, edsgarage1
strifemare - crwdns2934203:0crwdne2934203:0
Good idea with the gloves. I was not paying attention to fingerprints, I was more concerned about dog hair as I did this on the basement floor.
edsgarage1 -
Hi, this is a great guide. I have followed it and done it all by myself. The repair guy asked me for 800 CNY (~110USD) for reparing, so I decided to repair it myself, it only costed me 36 CNY (5 USD) for the purchase of the LED strips on Taobao.
Very useful guide, thanks again!
blurry222 - crwdns2934203:0crwdne2934203:0
Bonjour moi j'ai un soucis avec les contactes sur les leds neuves elles ne s'allument pas partout je pense que cela vient des embouts de contact des 2 leds un peu déterioré sur les 2 cordons ? ya t'il une solutions
Merci pour la réponse
Gilloupe - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 48
crwdns2936753:07crwdne2936753:0 285
crwdns2936753:030crwdne2936753:0 1,261
crwdns2942667:0crwdne2942667:0 68,052
