Komplete Audio 2 USB port replacement
  1. Komplete Audio 2 USB port replacement, Bottom cover screws: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Komplete Audio 2 USB port replacement, Bottom cover screws: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Komplete Audio 2 USB port replacement, Bottom cover screws: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The interface has 6 screws holding its bottom cover. In this step, we're going to remove them.
    • Place the device bottom up.
    • Using a Phillips #1 screwdriver, remove the 6 screws from the bottom cover.
    • Please note that the middle screw is located behind the product label.
  2. Komplete Audio 2 USB port replacement, Bottom cover detachment: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Besides the screws we removed already, the bottom cover uses 4 plastic tabs (two tabs on the front of the device and two on the sides).
    • Pry the plastic tabs to remove the bottom cover.
    • It shouldn't require much force to open the cover once the screws are removed (I broke one of the tabs trying to open the device with the middle screw still in place).
  3. Komplete Audio 2 USB port replacement, Ribbon cable connectors: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Komplete Audio 2 USB port replacement, Ribbon cable connectors: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Komplete Audio 2 USB port replacement, Ribbon cable connectors: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The main PCB has two ribbon cables connected to it. In this step, we're going to make sure they can be safely disconnected.
    • Unlock the ribbon cables by pulling on the grey plastic bits of their connectors (as indicated on the second image).
  4. Komplete Audio 2 USB port replacement, Ribbon cables: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Komplete Audio 2 USB port replacement, Ribbon cables: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Now that both of the ribbon cables are unlocked we can safely disconnect them from the main PCB.
    • Disconnect both ribbon cables by gently pulling them out of their connectors (you may need to wiggle the cables to the sides a little).
  5. Komplete Audio 2 USB port replacement, Main PCB screws: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Komplete Audio 2 USB port replacement, Main PCB screws: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Komplete Audio 2 USB port replacement, Main PCB screws: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The main PCB is held in place by 6 screws. In this step, we're going to remove them.
    • Using a Phillips #0 screwdriver, remove the 6 screws from the bottom cover.
  6. Komplete Audio 2 USB port replacement, Front panel screws: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Komplete Audio 2 USB port replacement, Front panel screws: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Komplete Audio 2 USB port replacement, Front panel screws: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • There are 2 screws attaching the front panel to the rest of the case. They are deeper inside the case, so they may not be immediately visible.
    • Using a Phillips #0 screwdriver, remove the 2 screws as shown on the photos.
  7. Komplete Audio 2 USB port replacement, Front panel detachment: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Komplete Audio 2 USB port replacement, Front panel detachment: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Komplete Audio 2 USB port replacement, Front panel detachment: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • With the screws removed, the front panel can be unclipped from the top cover.
    • Gently pry on the sides of the front panel as indicated by the arrows on the first image.
    • Pull on the front panel upwards until it detaches from the top cover.
    • This step takes some trial and error - take your time and try not to apply excessive force.
  8. Komplete Audio 2 USB port replacement, USB port cover: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Komplete Audio 2 USB port replacement, USB port cover: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The USB port has a plastic cover that's loosely attached to the main PCB. It's likely to fall out once the main PCB is pulled out.
  9. Komplete Audio 2 USB port replacement, USB port replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Komplete Audio 2 USB port replacement, USB port replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Komplete Audio 2 USB port replacement, USB port replacement: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • In order to replace the USB port you will need to desolder the one which is already in place first.
    • The locations of the relevant pins are indicated in the pictures 2 and 3.
    • If you're new to desoldering, take a look at this tutorial from Instructables: https://www.instructables.com/The-Ultima...
    • Desolder the USB port from the main PCB and then solder in the replacement.
Kuba M
crwdns2935283:003/13/22crwdne2935283:0
259 crwdns2915208:0crwdne2915208:0
crwdns2936753:030crwdne2936753:0 44
crwdns2942667:0crwdne2942667:0 1,600
