Use this guide to remove and install the front case on your Kodak EasyShare C913 camera. Before you begin, make sure to remove the battery and unplug from the charger.
Position the camera with the bottom facing up.
Slide the battery cover in the direction of the arrow with your finger gently.
Remove the batteries
Remove the seven 4.5mm screws with a Phillips #00 screwdriver.
2 screws on the left
2 screws on the right
3 screws on the bottom
Firmly grasp the back of the camera and pull the casing away.
Keep the battery door open
Firmly grasp the front casing and pull it away from the camera.
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Preciso da tampa da bateria...
