KitchenAid Professional 600 Power Cord Replacement
  1. KitchenAid Professional 600 Power Cord Replacement, Top Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Take out the screw which holds on the silver band using a Phillips #2 screwdriver.
    • Remove the silver band.
    Maybe start with unplugging it ?
    Ryan F - crwdns2934203:0crwdne2934203:0
  2. KitchenAid Professional 600 Power Cord Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the four Phillips #2 screws located around the mixer where the band was removed.
    • This picture only shows two of the screw that you need to remove. The other two are on the exact opposite side of the mixer.
  3. KitchenAid Professional 600 Power Cord Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the top of the mixer to reveal the inner parts.
    • The top should lift off, but may not if it is stuck. A sharp strike from the back with the hand may unstick it. It will slide forward about a 3/8 of an inch. Push it back again from the front and it should be free enough to lift.
  4. KitchenAid Professional 600 Power Cord Replacement, Speed Selector: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Locate the selector switch.
    • Remove the two Phillips #2 screws holding the selector switch in place.
  5. KitchenAid Professional 600 Power Cord Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 KitchenAid Professional 600 Power Cord Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 KitchenAid Professional 600 Power Cord Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unplug the cords attached the drive motor to the switch.
    • We suggest numbering them left from right so they are reattached to the replacement part in the right order.
    I would suggest labeling with what they go to (line, motor 1, etc) since at least for the HD version they changed the board layout so you need the labels to match them up.
    kevincash - crwdns2934203:0crwdne2934203:0
  6. KitchenAid Professional 600 Power Cord Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull out the Selector Switch.
    Somewhere between steps 4 and 7, you removed the planetary cover. This is just two more screws and must happen before the motor will lift out.
    Steve Muhween - crwdns2934203:0crwdne2934203:0
    Oops, make that 4 more screws. Still, it's easy. Just a little gooey with the transmission grease, so mind you don't get any dirt or whatnot in there when it's open.
    Steve Muhween -
  7. KitchenAid Professional 600 Power Cord Replacement, Drive Motor: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two Phillips #2 screws holding the motor in place, located near the fan at the back of the motor.
    • The picture only shows one of the screws. The other screw is located on the exact opposite side of the motor.
  8. KitchenAid Professional 600 Power Cord Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull upward to remove the motor.
    You missed the step about removing the gearbox cover, even though it is shown as removed in the pictures. The motor cannot be removed with the gearbox cover in place. For anyone doing this repair, remove the four phillips screws holding the cover on and lift upwards. It is full of grease so have some paper towels handy in case any spills. When replacing the cover (after re-installing the motor) you may need to spin the gears (do this by rotating the motor fan) so that the accessory drive gear meshes properly in order for the cover to fit back into place. Be sure to align the planetary shaft with the recess in the gearbox cover as well.
    Keith Everline - crwdns2934203:0crwdne2934203:0
  9. KitchenAid Professional 600 Power Cord Replacement, Power Cord: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the Phillips #2 screw attaching the green grounding wire to the frame of the mixer.
  10. KitchenAid Professional 600 Power Cord Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the three Phillips #2 screws that connect the top portion of the mixer to the "neck" of the mixer.
  11. KitchenAid Professional 600 Power Cord Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the top portion of the mixer from the "neck" of the mixer.
    • This will make removing the power cord much easier.
  12. KitchenAid Professional 600 Power Cord Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • You can now remove the power cord from the mixer.
Luke
crwdns2935283:004/11/16crwdne2935283:0
1,380 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 25-4, Maness Spring 2016 crwdns2935289:0Cal Poly, Team 25-4, Maness Spring 2016crwdne2935289:0
CPSU-MANESS-S16S25G4
crwdns2935297:020crwdne2935297:0
So helpful thank you. I've got my mixer cord changer and the mixer is working now. Unfortunately there's always only one speed, high. Any suggestions?
Britter C - crwdns2934203:0crwdne2934203:0
Any idea where I can buy the power cord itself?
Jaeger Amzallag - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 6,443
