Is your power cord frayed or damaged? Follow this guide to replace it.
Insert the back of a plastic opening tool into one of the beater holes
Apply force to pull the circular plastic part off.
If necessary, use the other side of the plastic opening tool to pry the circular plastic part off.
Use a plastic opening tool to remove the speed knob.
Pop up the panel with a plastic opening tool.
Use a plastic opening tool to pry the white plastic switch assembly out.
Use a Phillips 2 screwdriver to remove the two 20.0mm screws that hold the bottom plastic piece.
Remove the bottom plastic piece using a plastic opening tool.
Using a Phillips 2 screwdriver, remove the three 20.0mm screws holding the motor assembly in place.
Use your hands to remove the motor assembly and circuit board.
Firmly grip the circuit board, and using pliers, remove the black and white power cord connectors from the circuit board.
Using a plastic opening tool, remove the white plastic clip on the inside of the bottom plastic piece.
Once it's loose, remove it with your fingers.
Pull the power cord through the hole.
These instructions will be super helpful once I find a replacement power cord. Does anyone know where I can buy a cord?
where to find this cord?
