KitchenAid Classic Mixer K45SSWH Circuit Board Replacement
  1. KitchenAid Classic Mixer K45SSWH Circuit Board Replacement, Remove Back Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 KitchenAid Classic Mixer K45SSWH Circuit Board Replacement, Remove Back Cover: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a Phillips #2 screwdriver, remove the 10 mm screw from the top of the back cover.
    • The rear cover is now completely free from the mixer.
  2. KitchenAid Classic Mixer K45SSWH Circuit Board Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 KitchenAid Classic Mixer K45SSWH Circuit Board Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a Phillips #1 screwdriver, remove the 9.5 mm screw holding the circuit board in place.
    • The screw may be hidden underneath the seal.
  3. KitchenAid Classic Mixer K45SSWH Circuit Board Replacement, Dislodge Connectors: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 KitchenAid Classic Mixer K45SSWH Circuit Board Replacement, Dislodge Connectors: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using pliers, remove the connections for each of the four wires connecting to the circuit board.
    • Remember which color wire corresponds to which connection or take a photo. Improper placement will not allow your mixer to turn on.
  4. KitchenAid Classic Mixer K45SSWH Circuit Board Replacement, Remove Circuit Board: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Grab the four wires away from the circuit board.
    • Tilt the board back to remove it.
    • If the board won't come out with some wiggling, you may need to loosen the two screws at the top of the control plate. Mark the top of the heads and loosen them 5 complete turns, without removing them completely. You may need to loosen the locking nuts.
    Wo bitte kann ich eine neue Leiterplatte bekommen?
    Bei mir geht die erste Schaltstufe nicht und ich muss mit dem zeiten Gang starten, was mir die Zutaten aus der Schüssel schleudert.
    Danke für eine Antwort.
    Wolfgang Schrey - crwdns2934203:0crwdne2934203:0
    Google hilft mit “Kitchen Aid Ersatzteile”. z.B. hier oder hier
    VauWeh -
Chris Gonzales
crwdns2935283:010/12/14crwdne2935283:0
1.629 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 14-28, Maness Fall 2014 crwdns2935289:0Cal Poly, Team 14-28, Maness Fall 2014crwdne2935289:0
CPSU-MANESS-F14S14G28
crwdns2935297:022crwdne2935297:0
crwdns2947412:09crwdne2947412:0
To protect the board, be sure to put heat-sink compound on the back of the new circuit (phase) board to ensure proper heat transfer to the housing.
Finkerbell - crwdns2934203:0crwdne2934203:0
If the mixer gets locked up, can it cause the circuit board to go bad? Mine jammed due to a bad gear, now the motor won't run. I have juice to the board. Any suggestions?
Kevin - crwdns2934203:0crwdne2934203:0
Hi Chris I bought a secondhand kitchenaid mixer MODEL KSM75WH .. I was whipping meringue on a medium to high speed next thing there was an explosion black smoke coming from the machine, electrical burn smell…. Machine stopped and tripped my electricity.. can this be fixed …any idea what part needs to be replaced? Regards Savannah
savannah bach - crwdns2934203:0crwdne2934203:0
hallo,
meine KidchenAid sagt seit heute nichts mehr. Es hat einmal geknallt und die Sicherung ist raus geflogen. Als ich den Elektronikdeckel hinten aufgeschraubt habe kam mir eine kleine Rolle auf einem Federdraht entgegen geflogen. Ich weiß nicht wo sie hingehört. Kann sie hier auf den Bildern nicht entdecken. Kann mir jemand sagen wo das Ding hingehört?
Danke Christian
chrmoehl - crwdns2934203:0crwdne2934203:0
Hi, my kitchenAid mixer stop working. My wife was using it and she stop the machine and when try to turn in on again it won't start. I replaced the carbons but still the same it won't start. What can it be?
fajardof - crwdns2934203:0crwdne2934203:0
Long time ago but did you check the shaved off edges and aligned it properly into the holes? This solved my issue :)
Nadine Heller -
Hallo
Wir haben den Deckel hinten abgenommen und den alustreifen um das ausgetretene öl weg zu putzen.
Wirklich nix anderes gemacht Deckel wieder drauf machiene läuft nicht mehr
Kann mir einer sagen was das sein kann???Hilfe
Ingo Sehrig - crwdns2934203:0crwdne2934203:0
Dear all,
I am facing the same issue as all users. My wife was mixing and requested me to repair it. So I removed the cover and the carbons to have a look inside and changed nothing. After reassembling everything nothing happens. Very strange. Anyone any ideas what went wrong or what to consider when re-assembeling it? TIA! BR, John
Nadine Heller - crwdns2934203:0crwdne2934203:0
Alright. It is very important to align the brushes/carbons correctly in to the holes. Then the machine will run again without problems.... :)
Nadine Heller -
crwdns2936753:07crwdne2936753:0 19
crwdns2936753:030crwdne2936753:0 71
crwdns2942667:0crwdne2942667:0 21,079
