Keurig K-Duo Water Pump Replacement
  1. Keurig K-Duo Water Pump Replacement, Rear Plastic Panels: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Turn the Keurig K-Duo upside down so the power cord is visible and facing you.
  2. Keurig K-Duo Water Pump Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Keurig K-Duo Water Pump Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Keurig K-Duo Water Pump Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a Phillips screwdriver to remove all four screws that secure the plastic panel.
  3. Keurig K-Duo Water Pump Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Keurig K-Duo Water Pump Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Keurig K-Duo Water Pump Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • To remove the back panels, grip each side firmly.
    • Gently pull the panel outward toward yourself to release and fully detach the plastic hooks.
  4. Keurig K-Duo Water Pump Replacement, Water Pump: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Keurig K-Duo Water Pump Replacement, Water Pump: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • There are two terminal blocks to remove from the motherboard.
    • Gently disconnect the 2-pin terminal block that has the label "Water Pump" on the motherboard.
    • Gently disconnect the 4-pin terminal block that has the label "IR Sensor."
  5. Keurig K-Duo Water Pump Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Keurig K-Duo Water Pump Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Keurig K-Duo Water Pump Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull out the water pump from its socket by twisting it so that the bottom is facing you.
    • Remove the plastic tubes from water pump.
  6. Keurig K-Duo Water Pump Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Keurig K-Duo Water Pump Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Fully access the water pump by pulling it straight out.
    • Make sure none of the disconnected wires are caught on any of the motherboard components to avoid damage.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Jacob Archer
crwdns2935283:010/28/24crwdne2935283:0
212 crwdns2915208:0crwdne2915208:0
Cuesta, Team 10-3, Krynen Fall 2024 crwdns2935289:0Cuesta, Team 10-3, Krynen Fall 2024crwdne2935289:0
CUESTA-KRYNEN-F24S10G3
crwdns2936753:030crwdne2936753:0 117
crwdns2942667:0crwdne2942667:0 957
