Keurig K-Duo Motherboard Replacement
  1. Keurig K-Duo Motherboard Replacement, Rear Plastic Panels: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Turn the Keurig K-Duo upside down so the power cord is visible and facing you.
  2. Keurig K-Duo Motherboard Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Keurig K-Duo Motherboard Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Keurig K-Duo Motherboard Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a Phillips screwdriver to remove all four screws that secure the plastic panel.
  3. Keurig K-Duo Motherboard Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Keurig K-Duo Motherboard Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Keurig K-Duo Motherboard Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • To remove the back panels, grip each side firmly.
    • Gently pull the panel outward toward yourself to release and fully detach the plastic hooks.
  4. Keurig K-Duo Motherboard Replacement, Motherboard: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Keurig K-Duo Motherboard Replacement, Motherboard: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently disconnect all eleven connectors from the motherboard.
    • Gently pull off the four remaining wire terminals.
    • It may be helpful to label each terminal for its original corresponding connection.
    • Be careful not to damage green wire. It will have to be removed by soldering.
  5. Keurig K-Duo Motherboard Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Keurig K-Duo Motherboard Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull out and flip the motherboard so the back is now facing you.
    • Desolder the solder pad connected to the green wire.
    • Re-solder the existing green wire to the new motherboard.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Adrian Guzman
crwdns2935283:010/28/24crwdne2935283:0
598 crwdns2915208:0crwdne2915208:0
Cuesta, Team 10-3, Krynen Fall 2024 crwdns2935289:0Cuesta, Team 10-3, Krynen Fall 2024crwdne2935289:0
CUESTA-KRYNEN-F24S10G3
What are the 4 leads that protrude from the motherboard to a recess(covered) on the bottom of the Kuerig? Are these test points for the motherboard? If so, how do I test the board and what values should I look for?
Rich - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 23
crwdns2936753:030crwdne2936753:0 89
crwdns2942667:0crwdne2942667:0 617
