Karcher Pressure Washers 11073080 2017 Pump Assembly Replacement
  1. Karcher Pressure Washers 11073080 2017 Pump Assembly Replacement, Disconnect the spark plug: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Karcher Pressure Washers 11073080 2017 Pump Assembly Replacement, Disconnect the spark plug: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Before you begin, be sure that the engine is powered off and is cool to the touch.
    • Grab the plastic housing at the end of the spark plug wire.
    • Pull firmly to disconnect the wire from the spark plug.
  2. Karcher Pressure Washers 11073080 2017 Pump Assembly Replacement, Remove the pump assembly: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Karcher Pressure Washers 11073080 2017 Pump Assembly Replacement, Remove the pump assembly: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a 14 mm socket to remove the four bolts securing the pump assembly to the pressure washer.
  3. Karcher Pressure Washers 11073080 2017 Pump Assembly Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Karcher Pressure Washers 11073080 2017 Pump Assembly Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull the pump assembly straight off of the pressure washer to remove it.
    you effing kidding me? mine is locked tight
    ROBERT - crwdns2934203:0crwdne2934203:0
    LOL!!! try to pull it off by hand...
    BTW why don't they apply marine grease to the shaft when they build these things?
    CHRISTOPHER - crwdns2934203:0crwdne2934203:0
    In order to get the pump off, you must open the pump cover, remove the bolts holding the pistons together (2 each Piston, 6 total). After which the pump will slide off.
    JAMES - crwdns2934203:0crwdne2934203:0
  4. Karcher Pressure Washers 11073080 2017 Pump Assembly Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • During reassembly, insert the square key into the slot on the pump motor shaft before you reinstall the pump assembly.
  5. Karcher Pressure Washers 11073080 2017 Pump Assembly Replacement, Replace the dipstick: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Karcher Pressure Washers 11073080 2017 Pump Assembly Replacement, Replace the dipstick: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The new pump assembly will come with a plug in the oil port. After installing the new pump assembly, remove this plug.
    • Replace the plug with the dipstick from the old pump assembly.
Adam O'Camb
crwdns2935283:004/11/15crwdne2935283:0
210,968 crwdns2915208:0crwdne2915208:0
crwdns2935297:0416crwdne2935297:0
Estamos interesados en un kit de reconstruccion de una bomba Karcher HD 9/23 DE
Atentamente,
Vicente
Vicente Garcia - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 49
crwdns2942667:0crwdne2942667:0 2,196
