Karcher Carpet Cleaner 10066730 2014 Switch Replacement
  1. Karcher Carpet Cleaner 10066730 2014 Switch Replacement, Remove the screws securing the front panel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Before beginning repairs, disconnect the device from power, disconnect all hoses, drain and depressurize the system, and let the device cool if the heater was recently used.
    • Use a Phillips screwdriver to remove the six screws securing the front panel.
  2. Karcher Carpet Cleaner 10066730 2014 Switch Replacement, Tilt the front panel down: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Karcher Carpet Cleaner 10066730 2014 Switch Replacement, Tilt the front panel down: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Grip the front panel at the top and tilt down to reveal the switch electronics.
    • The front panel will stay attached to the device with the flexible tubing.
  3. Karcher Carpet Cleaner 10066730 2014 Switch Replacement, Remove the wires from the switch: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Karcher Carpet Cleaner 10066730 2014 Switch Replacement, Remove the wires from the switch: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Grip the black ground wire by its blue connector and pull directly away from the switch to remove it.
  4. Karcher Carpet Cleaner 10066730 2014 Switch Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Karcher Carpet Cleaner 10066730 2014 Switch Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the grey wire from the switch.
  5. Karcher Carpet Cleaner 10066730 2014 Switch Replacement, Depress the retaining clips: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Karcher Carpet Cleaner 10066730 2014 Switch Replacement, Depress the retaining clips: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pinch the retaining clips on the back of the switch housing.
    • There are four retaining clips, two on the top and two on the bottom. All four will need to be depressed so the switch can slide out of the front panel.
  6. Karcher Carpet Cleaner 10066730 2014 Switch Replacement, Remove the switch: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Karcher Carpet Cleaner 10066730 2014 Switch Replacement, Remove the switch: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Karcher Carpet Cleaner 10066730 2014 Switch Replacement, Remove the switch: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • With all four retaining clips depressed, push the switch through and off of the front panel.
    • The switch will slide out of the front panel without much force.
    • Remove the switch.
Carsten Frauenheim
145.999 crwdns2915208:0crwdne2915208:0
crwdns2935297:0424crwdne2935297:0
Staff
crwdns2931471:0119crwdne2931471:0
crwdns2935297:021.724crwdne2935297:0
my machine has power but isn't turn on , already change switches (4) and also change the breaker and still doesn't turn on!
JUAN - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 652
