Jura Impressa S Model magnetic valve replacement
  1. Jura Impressa S Model magnetic valve replacement, How to open a Jura Impressa S model cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Jura Impressa S Model magnetic valve replacement, How to open a Jura Impressa S model cover: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Always remove the power cord from the wall outlet.
    • Lift out the coffee tray
    • Remove the lid sealing the coffee bean container
    • Remove all of the coffee beans you can possibly remove.
    • Pull the adjuster of the coffee bean grinder straight up
    • Remove the four T15 Torx screws
    With the Impressa XS 90 there is an additional ground beans funnel that needs to be removed that hides two of the four torx screws
    Ian Channing - crwdns2934203:0crwdne2934203:0
  2. Jura Impressa S Model magnetic valve replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Jura Impressa S Model magnetic valve replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the cup heat plate.
    • It can be opened like a book.
    • Below the cup heat plate there are three more T15 Torx screws. Remove them.
  3. Jura Impressa S Model magnetic valve replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The top cover is now free. Lift ´er up and set ´er aside.
    With the Impressa XS 90 there is an additional cover above the grinder that has wires glued to it that prevents you from taking the top completely off.
  4. Jura Impressa S Model magnetic valve replacement, Jura Impressa S model backpanel: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Jura Impressa S Model magnetic valve replacement, Jura Impressa S model backpanel: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Jura Impressa S Model magnetic valve replacement, Jura Impressa S model backpanel: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    iFixit Precision 4 mm Screwdriver Bit
    $2.99
    • The backpanel is secured with two proprietary screws with oval head. They seem to be rivets, but in fact are screws. The only purpose is, to keep us out of our own devices. You can remove them using an oval drive bit. (Part of some IFixit tool collections or available at a Jura provider or iFixit). In a pitch try needle nose pliers. Here a DIY guide.
    • Remove the two oval head screws on the lower edge of the backpanel.
    • Lift the panel up.
  5. Jura Impressa S Model magnetic valve replacement, Jura Impressa S model front cover: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Jura Impressa S Model magnetic valve replacement, Jura Impressa S model front cover: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the knob for the steam valve by simply pulling it off.
    • The front cover is secured with a Torx T15 screw. Remove it.
  6. Jura Impressa S Model magnetic valve replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Now the front cover can be opened like a door for a few inches. The hinge is on the left.
  7. Jura Impressa S Model magnetic valve replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Various hoses hinder the further opening of the front cover. You need to remove the steam valve keypad from the cover.
    • Use a spudger to lift the two notches at the top of the front cover a bit to release the keypad at the top.
    • Lift the keypad upwards and pull it to the back. The steam pipe will slide out from its connection.
    • All hoses can remain connected.
  8. Jura Impressa S Model magnetic valve replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the silicone hose leading from the steam valve to the coffee spout. If it is secured with a cable tie which must be removed first.
    • The front cover is now free and can be opened.
  9. Jura Impressa S Model magnetic valve replacement, Magnetic Valve: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Jura Impressa S Model magnetic valve replacement, Magnetic Valve: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Jura Impressa S Model magnetic valve replacement, Magnetic Valve: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The solenoid valve is located at the top left rear of the machine. (Marked in orange). It is installed in the sloping part of the cage for the heaters. The valve can be easily removed without pulling out the cage. If you do want to pull out the cage, you can find the instructions here.
  10. Jura Impressa S Model magnetic valve replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Jura Impressa S Model magnetic valve replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The white support of the valve is fixed in two slotted holes in the slanted part of the metal cage. The carrier must be shifted upwards by about 1 cm, then the valve can be lifted out.
    • The carrier is held in place by two small plastic catches. Press the plastic catches in from below with an angled pointed tool, then the catches are free.
  11. Jura Impressa S Model magnetic valve replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Jura Impressa S Model magnetic valve replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the valve out upwards.
    • The valve is still connected to three cables. Pull off the cable lugs, note the position.
    • The valve is connected with hoses at the front and rear. Pull out the clamps and disconnect the hoses. An O-ring is attached to the hose for sealing. It gets stuck on the hose or in the valve. Replace it with a new one when reassembling.
    • There are valves that are equipped with Legris connections. Here there are no clamps, but the hoses must be pressed towards the valve, then the small ring on the connection must also be pressed towards the valve. Then the hose can be pulled out with a little force.
    Danke für die ausführliche Anleitung
    Könnte damit eine Ventil erfolgreich austauschen.
    Kaffee fließt wieder .
    adel Belghache - crwdns2934203:0crwdne2934203:0
Work through the steps in reverse order to reassemble your device.
crwdns2934873:0crwdne2934873:0
de en
100%
crwdns2934883:0shinglecrwdne2934883:0 crwdns2934875:0crwdne2934875:0
crwdns2934877:0crwdne2934877:0 ›
VauWeh
crwdns2935283:010/19/15crwdne2935283:0
258.220 crwdns2915208:0crwdne2915208:0
crwdns2935297:0293crwdne2935297:0
Very similar for the XS90, which has the acl 0045418 v32e.
In my case the rings were actually fine, but disassembly of the valve revealed chalk buildup on the stem which hampered movement.
Cleaning that off fixed it.
Mark - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 53
crwdns2942667:0crwdne2942667:0 3,534
