Jumper Angelsounds JPD-100S Volume Knob Replacement
  1. Jumper Angelsounds JPD-100S Volume Knob Replacement, Motherboard: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Access the battery compartment
    • Remove the battery compartment lid and set it aside.
    • Disconnect the battery and set it aside.
  2. Jumper Angelsounds JPD-100S Volume Knob Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Jumper Angelsounds JPD-100S Volume Knob Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Puncture the sticker in the battery compartment with a spudger to access the screw beneath it.
  3. Jumper Angelsounds JPD-100S Volume Knob Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the 7mm Phillips #1 screw from the battery compartment.
    • Place the screw in a secure place.
  4. Jumper Angelsounds JPD-100S Volume Knob Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Jumper Angelsounds JPD-100S Volume Knob Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Begin prying open the device.
    • Insert a plastic opening tool into the side groove about 2cm from the pink plastic component and pry open one side of the device.
    • Once the side is separated, leave the opening tool inside to prevent the two sides from closing.
  5. Jumper Angelsounds JPD-100S Volume Knob Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Jumper Angelsounds JPD-100S Volume Knob Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert another plastic opening tool into the groove opposite to the side of the tool already inserted.
    • Create separation on that side until the white plastic component comes off entirely.
    • Place the white plastic component in a secure place.
  6. Jumper Angelsounds JPD-100S Volume Knob Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • With your hand, remove the pink component.
  7. Jumper Angelsounds JPD-100S Volume Knob Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the 7mm Phillips #1 screw in the middle of the motherboard.
  8. Jumper Angelsounds JPD-100S Volume Knob Replacement, Volume Knob: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Jumper Angelsounds JPD-100S Volume Knob Replacement, Volume Knob: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the white glue on the volume knob by peeling it off or gently using tweezers to pull it out.
    • Allow approximately 10 minutes for the soldering station to heat up before using.
  9. Jumper Angelsounds JPD-100S Volume Knob Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Jumper Angelsounds JPD-100S Volume Knob Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the 5mm Phillips #00 screw holding the volume knob to the motherboard.
    • Place the screw and volume knob in a secure, safe place.
  10. Jumper Angelsounds JPD-100S Volume Knob Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Jumper Angelsounds JPD-100S Volume Knob Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Jumper Angelsounds JPD-100S Volume Knob Replacement: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unsolder the five points holding the volume knob to the motherboard.
    • Carefully place the soldering iron down, as you will need it for reassembly.
Melanie Orozco
crwdns2935283:008/31/15crwdne2935283:0
143 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 6-1, Remmell Fall 2015 crwdns2935289:0USF Tampa, Team 6-1, Remmell Fall 2015crwdne2935289:0
USFT-REMMELL-F15S6G1
crwdns2931471:06crwdne2931471:0
crwdns2942667:0crwdne2942667:0 291
