Joy-Con ZL Switch Replacement
  1. Joy-Con ZL Switch Replacement, Unscrew the back cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using the Y00 Tri-Point screwdriver, remove four M1.4 x 5mm screws to loosen the hard plastic back of the Joy-Con.
    My lil brother threw my switch but screen was not broken but the ZL button fell out
    Jarrett Swanson - crwdns2934203:0crwdne2934203:0
    My screw bit won’t work, all it’s doing is destroying the screw
    [deleted] - crwdns2934203:0crwdne2934203:0
    • After the screws are removed, lift the cover to reveal the inside of the Joy-Con and locate the ZL button.
    • The button exposed could either be the ZL or the ZR depending on which Joy-Con needs to be fixed.
  2. crwdns2935267:0crwdne2935267:0
    • Use tweezers to lift the ZL button a little then pull upwards to get it back into place.
    • Once the button is back in place, place the hard cover back on the Joy-Con and screw it back on.
    • Click the button a couple times to ensure that it's back in place and working.
    • This may either be the ZL or ZR button depending on the Joy-Con being fixed.
  3. Joy-Con ZL Switch Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Resume gameplay!
  4. Joy-Con ZL Switch Replacement, The problem part: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Joy-Con ZL Switch Replacement, The problem part: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • This tiny piece of metal had come off the small pcb and ribbon cable. In doing so it had jammed the switch.
    • Use the guide for un-jamming ZL switch, to remove the case screws, the top cover and the ZL switch and springs.
  5. Joy-Con ZL Switch Replacement, Splitting it apart: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Joy-Con ZL Switch Replacement, Splitting it apart: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Joy-Con ZL Switch Replacement, Splitting it apart: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Having removed the plastic button and 2 springs you uncover the switch and holding screw.
    • Remove the holding screw.
  6. Joy-Con ZL Switch Replacement, Pop out the battery: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Joy-Con ZL Switch Replacement, Pop out the battery: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the battery out of the battery chassis tray.Use a plastic splitter if necessary.
    • Do not remove the sticky tape underneath as this is unnecessary. It does not effect the repair.
  7. Joy-Con ZL Switch Replacement, Remove the battery tray: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Joy-Con ZL Switch Replacement, Remove the battery tray: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the 4 screws holding down the inner battery support chassis. This exposes the switch connector to the pcb.
    • Note the bottom left screw in this picture is shorter than the others and needs to be put back in the correct aperture.
  8. Joy-Con ZL Switch Replacement, Pulling the plug on the problem....: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently pull on the ribbon cable to remove the plug from the socket.
    • Insert plug on new ribbon cable & switch.
    • You may need to push in the plug with plastic tweezers. Take care not to damage the cable.
  9. Joy-Con ZL Switch Replacement, Putting it back together: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Replace batters chassis tray and screw back into place. Note to put back the shorter screw into the correct hole.
    • Fold battery back into place. Gently push down to get the battery stuck back to the tape.
    • Adjust the ribbon cable to ensure it is not trapped. Place the switch over the alignment pin and screw down the retaining screw.
  10. Joy-Con ZL Switch Replacement, Yippee it works!: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Joy-Con ZL Switch Replacement, Yippee it works!: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Joy-Con ZL Switch Replacement, Yippee it works!: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Put the two springs back on their retaining pins and push the button back into place.
    • It should click into place and when you push on the button you should hear the switch click.
    • Fold the cover back over and check there are no trapped wires before screwing back the 4 screws on the cover to complete the repair.
Robin Razzell
crwdns2935283:009/04/13crwdne2935283:0
313 crwdns2915208:0crwdne2915208:0
This doesn’t really cover the removal of the ZL/ZR Buttons.
It is good for removing the actual button on the mother board, but not for removing the plastic button on the remote.
OreoDestroyer93 - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 14
crwdns2936753:07crwdne2936753:0 69
crwdns2936753:030crwdne2936753:0 340
crwdns2942667:0crwdne2942667:0 9,151
