Jazz UltraTab C855 Battery Replacement
  1. Jazz UltraTab C855 Battery Replacement, Back Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
  2. Jazz UltraTab C855 Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pry the back case off using the blue Plastic Opening Tools. Work one along the seem until you can get your fingers under to pull it apart.
  3. Jazz UltraTab C855 Battery Replacement, Battery: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the yellow tape from the sides of the battery, and the surrounding components.
  4. Jazz UltraTab C855 Battery Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Cut the pos(+) and neg (-) wires that connect the battery to the device using wire cutters.
    • Cut the wires towards the middle. During installation of your new battery these wires will be stripped back and soldered or crimped to reattach.
  5. Jazz UltraTab C855 Battery Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a plastic opening tool or spudger, slowly pry the battery away from the board.
    • The battery is secured to the device with adhesive.
    • Metal spudgers can puncture an unprotected battery, potentially causing a fire. When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The regular black nylon spudger or a plastic opening tool should be used whenever possible.
  6. Jazz UltraTab C855 Battery Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a two sided adhesive to secure the new battery in place.
    • Solder or crimp the wires back together to reattach to the motherboard.
    • Replace any yellow tape that you removed at the beginning to secure the wires back in place.
Cory Hodge
crwdns2935283:009/14/15crwdne2935283:0
201 crwdns2915208:0crwdne2915208:0
IUPUI, Team 1-3, Baechle Fall 2015 crwdns2935289:0IUPUI, Team 1-3, Baechle Fall 2015crwdne2935289:0
IUPUI-BAECHLE-F15S1G3
Very good instructions.....but where do I buy the repkacement battery from?
fremontmyers - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 51
crwdns2942667:0crwdne2942667:0 618
