Jabra Freeway Microphone Replacement
Alec Wilson
crwdns2944109:0crwdnd2944109:0Alec Wilsoncrwdnd2944109:0crwdnd2944109:0crwdnd2944109:0crwdne2944109:0
crwdns2944111:0N'w 22, 2016crwdne2944111:0
15 - 45 crwdns2931279:0crwdne2931279:0
crwdns2937595:0crwdne2937595:0
crwdns2942287:0crwdne2942287:0
In this guide you will be replacing the microphone of the Jabra Freeway.
crwdns2944105:0crwdne2944105:0
  1. Jabra Freeway Microphone Replacement, Front Panel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Jabra Freeway Microphone Replacement, Front Panel: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Jabra Freeway Microphone Replacement, Front Panel: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Turn off the device before proceeding. Failure to do so may result in device damage or injury to oneself.
    • Remove the rubber pads from the bottom of the device using the spudger.
  2. Jabra Freeway Microphone Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Jabra Freeway Microphone Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Jabra Freeway Microphone Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the eight 6mm T9 screws.
    • Two of these screws are underneath the foam padding. This padding is glued on and will be destroyed in this process. Poking through the foam minimizes the damage to the device.
    Why not show us which 2 are under the foam padding?
    Doug - crwdns2934203:0crwdne2934203:0
  3. Jabra Freeway Microphone Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Jabra Freeway Microphone Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Jabra Freeway Microphone Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Gently lift the front panel off of the device and carefully rest it to the side.
  4. Jabra Freeway Microphone Replacement, Microphone: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Jabra Freeway Microphone Replacement, Microphone: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Jabra Freeway Microphone Replacement, Microphone: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the microphone from the microphone holding slot.
  5. Jabra Freeway Microphone Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Desolder the two wires connecting to the microphone.
    • Please refer to the soldering technique guide for instructions on desoldering and soldering.
Alec Wilson
crwdns2935283:010/19/16crwdne2935283:0
741 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team 4-8, Catania Fall 2016 crwdns2935289:0UMass Dartmouth, Team 4-8, Catania Fall 2016crwdne2935289:0
UMASSD-CATANIA-F16S4G8
Based on my limited experience with this device, the component being replaced here is the secondary, or noise-cancelling microphone - not to be confused with the primary microphone. The other video showing replacement of the motion detector seems to be actually replacing the primary microphone.
Steve MacLeod - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 6
crwdns2942667:0crwdne2942667:0 1,023
