Jabra Evolve2 65 Motherboard Replacement
  1. Jabra Evolve2 65 Motherboard Replacement, Ear Pads: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lay your headphones down on a flat, solid surface.
  2. Jabra Evolve2 65 Motherboard Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Jabra Evolve2 65 Motherboard Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert an opening tool into the seam between the ear pad and driver housing, near the hinge.
    • Gently pry the ear pad away from the driver housing until it releases.
  3. Jabra Evolve2 65 Motherboard Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Jabra Evolve2 65 Motherboard Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pry off the other ear pad in the same manner.
  4. Jabra Evolve2 65 Motherboard Replacement, Motherboard: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Jabra Evolve2 65 Motherboard Replacement, Motherboard: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Peel back the tape where the microphone's base connects to the headband.
    • Use a T6 Torx screwdriver to remove the single 2 mm screw.
  5. Jabra Evolve2 65 Motherboard Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Go about a third of the way around the first screw and peel back the tape to locate the second screw.
    • Use T6 Torx screwdriver to remove the single 2 mm screw.
  6. Jabra Evolve2 65 Motherboard Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Locate the third screw after peeling the tape off entirely after removing the second screw.
    • Use a T6 Torx screwdriver to remove the final 2 mm screw.
  7. Jabra Evolve2 65 Motherboard Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Jabra Evolve2 65 Motherboard Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Jabra Evolve2 65 Motherboard Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use an opening tool to pry up and set aside the driver housing.
    • Gently remove the motherboard from the housing..
  8. Jabra Evolve2 65 Motherboard Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Jabra Evolve2 65 Motherboard Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Jabra Evolve2 65 Motherboard Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • After locating the battery underneath, use a pair of tweezers to disconnect all connected cables.
    • Using tweezers, gently wiggle out the connector that joins the battery to the motherboard. The correct connector will be labeled on the motherboard and is the one that contains 2 wires, one black and one red.
  9. Jabra Evolve2 65 Motherboard Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a soldering iron, desolder the driver connections from the motherboard.
    • When reinstalling the driver to the motherboard, make sure you solder the driver connections to the correct terminals. The red wire goes to the "P" and the black wire goes to the "N."
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Nyles Nguyen
crwdns2935283:003/26/25crwdne2935283:0
269 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team 3-2, Botvin Spring 2025 crwdns2935289:0UMass Dartmouth, Team 3-2, Botvin Spring 2025crwdne2935289:0
UMASSD-BOTVIN-S25S3G2
Would it be able to share the source for the spare part?
Waldemar - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 95
crwdns2942667:0crwdne2942667:0 392
