Jabra Elite 85h Ear Cushion Replacement
  1. Jabra Elite 85h Ear Cushion Replacement, Ear Cushion: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Jabra Elite 85h Ear Cushion Replacement, Ear Cushion: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Jabra Elite 85h Ear Cushion Replacement, Ear Cushion: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove each ear cushion by hooking your fingers along the inside of the ear cushion and pulling up and away from the ear cup.
    • If the cushion does not fully release, move your hand to the opposite side and pull up inn the same manner.
    Hi sir, I think your guide is incomplete. Do you have the opportunity to bring a sequel?
    Oğuzhan Sancak - crwdns2934203:0crwdne2934203:0
    The battery is under the left earcup.
    NOT the earcup into which you plug the USB cable.
    Not sure why the demo asks you to disassemble the right earcup...
    Jimbo - crwdns2934203:0crwdne2934203:0
    These instructions could use some work! There is no need to disassemble both sides as the battery is under the left ear cup only.
    kelly1 - crwdns2934203:0crwdne2934203:0
    I have just disassembled mine, Jabra Elite 85h, model OTE100. The cushions (as described in this step) can not be removed. If that's the case, The foam in the center has to be removed to access the speaker screws. Undoing the screws will split the headphone in half, releasing the pad together with the speaker. This will uncover the rest of the components
    Besides, I agree with the rest of the comments - If you're after the battery there is no need to disassemble the right headphone as the battery resides in the left
    bystrzak14 - crwdns2934203:0crwdne2934203:0
    This is very easy. I just finished mine. You dont need special tools as a tweeser will pull the wire connection apart. The cushions will come off and are replaceable. Do just the left one. Pull it apart like you mean it. Do have a small piece of thick double-sided tape on hand. The AOLIKES 3.7v 850mAh battery from amazon works but the wire is a bit short to orient it like the original. Just don’t press it in place until the circuit board is screwed in place. All I can say now is that it’s charging.
    Lastly, I’ve learned from experience that if you’re using metal screws in plastic, when reassembling turn counter clockwise until you hear a click. Thats when they are aligned properly and you’re less likely to strip the thread.
    CJ ? - crwdns2934203:0crwdne2934203:0
To install the new cushions, position them in the ear cup and push down firmly so that they click into place.
Matt Gardiner
crwdns2935283:003/15/23crwdne2935283:0
351 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team 3-4, Petersen Spring 2023 crwdns2935289:0UMass Dartmouth, Team 3-4, Petersen Spring 2023crwdne2935289:0
UMASSD-PETERSEN-S23S3G4
No matter how hard I push, nothing moves. I have no idea what I am doing wrong, but it seems like the cushions are hard connected to the rest of the headset.
Christian Schmidt - crwdns2934203:0crwdne2934203:0
Cool for cats mate. Worked a treat. Didn’t realise they just popped out.
Silky Heineken - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 18
crwdns2936753:030crwdne2936753:0 121
crwdns2942667:0crwdne2942667:0 3,989
