If the zoom (+/-) buttons on your JVC Adixxion GC-XA1BU action camera are unresponsive, stuck, or damaged, replacing them may be necessary to restore full functionality. However, before proceeding with a replacement, it is important to troubleshoot the issue.
If the buttons are unresponsive, check if the camera's firmware is up to date and restart the device to rule out software issues. Make sure there is no dust or debris obstructing the buttons. If the buttons are cracked, missing, or not clicking properly, a replacement is needed.
If troubleshooting does not resolve the issue, follow this guide to safely and effectively replace the zoom (+/-) buttons on your JVC Adixxion GC-XA1BU.
Before you begin the repair, power off your camcorder and unplug it from the charger. Also, remove the battery.
Find the side of the camera with the black switch shown.
Slide the battery cover back while pushing down on the black switch.
Open the battery compartment and push the blue battery release switch.
Remove the two Phillips screws (4mm x 3mm) using the Phillips #00 screwdriver.
Remove the 8 screws (5mm x 4mm) from the corners of both the front and back of the camera (4 screws on each side) using the T6 Torx screwdriver.
Carefully open the camera as shown and gently peel off the black cover tape.
Carefully lift up and remove the cable ribbon clip using the tweezers.
Carefully grasp and remove the ribbon cable using the tweezers.
Turn the camera as shown and carefully remove the glue from the connector.
Carefully pull the white clip out of the casing using the tweezers.
Use a Phillips #00 screwdriver to remove the two top screws (4mmx x 3mm). Once the screws are removed, carefully lift off the silver plate using Tweezers.
Once you have lifted and removed the silver plate, use a Phillips #00 screwdriver to remove the two bottom screws (4mm x 3mm).
Using Tweezers, gently pull the red, black, and white threaded wire to disconnect it, then remove the attached panel as shown.
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
