JBL Xtreme Charging Port Replacement
  1. JBL Xtreme Charging Port Replacement, Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Locate the seams next to the 'feet' on the bottom side of the device.
  2. JBL Xtreme Charging Port Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 JBL Xtreme Charging Port Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the metal spudger to gently pry and lift the edge of the seam. The cover is held in place with plastic snaps that will make a popping noise when disengaged. !!Start with the back half, this will expose TWO Screws that need to be removed before lifting the front half.
  3. JBL Xtreme Charging Port Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 JBL Xtreme Charging Port Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • For the first part of the case: gently pull back the edges of the case rotating along the hinge opposite the opening seam illustrated in the second photo. Plastic snaps hold the cover in place.
    • For the second part of the case: there are 2 screws to be removed at the seam. Once removed, the case will come off completely without forcing.
  4. JBL Xtreme Charging Port Replacement, Bass Radiator: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 JBL Xtreme Charging Port Replacement, Bass Radiator: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 JBL Xtreme Charging Port Replacement, Bass Radiator: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unscrew the six 9.75mm Phillips head screws holding the bass radiator in place.
    • Three of the five outer screws are indicated in the first image and the sixth inner screw is indicated in the second image.
  5. JBL Xtreme Charging Port Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 JBL Xtreme Charging Port Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 JBL Xtreme Charging Port Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Once the screws have been removed, the bass radiator will easily lift free.
    • Both radiators are identical. Repeat the above steps on the opposite radiator if necessary.
  6. JBL Xtreme Charging Port Replacement, Charging Port: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 JBL Xtreme Charging Port Replacement, Charging Port: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 JBL Xtreme Charging Port Replacement, Charging Port: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Locate and disconnect the the three plugs indicated in these pictures.
  7. JBL Xtreme Charging Port Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 JBL Xtreme Charging Port Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unplug the three ports from the previous step.
    • A set of tweezers may be helpful to reach deeper into the device.
  8. JBL Xtreme Charging Port Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 JBL Xtreme Charging Port Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 JBL Xtreme Charging Port Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Locate the three Phillips head screws inside the zipper compartment and unscrew them.
    • Pull the zipper panel free from the device.
  9. JBL Xtreme Charging Port Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 JBL Xtreme Charging Port Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 JBL Xtreme Charging Port Replacement: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Under the zipper panel are eight more Phillips head screws. Unscrew them and carefully lift the battery cover.
    • Be careful not to damage the small white ribbon cable which connects the battery cover to the rest of the device.
  10. JBL Xtreme Charging Port Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 JBL Xtreme Charging Port Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unscrew the three 11.88mm Phillips head screws highlighted in the picture.
  11. JBL Xtreme Charging Port Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 JBL Xtreme Charging Port Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull the Auxiliary board out.
    • There is foam covering the wires, making it difficult to remove the Auxiliary board. Take your time with this step.
  12. JBL Xtreme Charging Port Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 JBL Xtreme Charging Port Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 JBL Xtreme Charging Port Replacement: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The first image highlights the charging port.
    • Locate 6 metal pins highlighted in the second image and use a solder iron to disconnect the pins.
crwdns2935229:017crwdne2935229:0
Benny Huynh
crwdns2935283:002/15/17crwdne2935283:0
2 022 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 1-1, Sullivan Spring 2017 crwdns2935289:0USF Tampa, Team 1-1, Sullivan Spring 2017crwdne2935289:0
USFT-SULLIVAN-S17S1G1
crwdns2935297:028crwdne2935297:0
Please I have a JBL XTREME that sparks each time I plug it. What could be the cause
morris_ugwoke - crwdns2934203:0crwdne2934203:0
Hi. Can someone advise where a replacement charging port can be sourced? I.e., so I can desolder the existing one and solder a new one in its place. The existing one is badly corroded so the unit won't charge. Thanks Andy
Andy R - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 58
crwdns2936753:030crwdne2936753:0 291
crwdns2942667:0crwdne2942667:0 26,146
