JBL Xtreme 3 Tweeters Replacement
  1. JBL Xtreme 3 Tweeters Replacement, Exterior Speaker Shell Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Find the seam on the speaker and position it upwards.
    • Begin by turning the device to where the bottom side with groves are facing towards you, using the (5) spudger carefully pry open the side of the outer shell where the red indicators are to unlatch outer shell. After they are unlatched you should be able to open the shell by hand.
  2. JBL Xtreme 3 Tweeters Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • To continue to remove the outer shell unscrew the two screws (size 1cm) shown in the picture with a size 0 (zero) Phillip's screwdriver.
  3. JBL Xtreme 3 Tweeters Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 JBL Xtreme 3 Tweeters Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • To continue to remove the shell use a (5) spudger to slowly pop the shell off.
    • There is one nudge in the center below the power and bluetooth button that should pop off.
    • Once you have unlatched this piece correctly the shell will remove itself from the speaker itself. As it is shown in the following figure.
  4. JBL Xtreme 3 Tweeters Replacement, Tweeters: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully turn the JBL devices on its side
    • Locate the 4 screws connecting the piece of hardware containing the tweeters and the piece of hardware containing the motherboard.
    • With a Phillip Screwdriver unscrew those 4 screws
  5. JBL Xtreme 3 Tweeters Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • With the Sharp end of the Spudger
  6. JBL Xtreme 3 Tweeters Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Repeat steps 1 and 2 on the other side of the JBL Device
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Eniola Owolabi
crwdns2935283:011/09/23crwdne2935283:0
223 crwdns2915208:0crwdne2915208:0
IUPUI, Team 2-5, Harley Fall 2023 crwdns2935289:0IUPUI, Team 2-5, Harley Fall 2023crwdne2935289:0
IUPUI-HARLEY-F23S2G5
crwdns2942667:0crwdne2942667:0 584
