JBL Flip 5 Buttons Replacement
  1. JBL Flip 5 Buttons Replacement, Outer Case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 JBL Flip 5 Buttons Replacement, Outer Case: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert the flat edge of the metal spudger underneath the corner of the outer case.
    • Use the spudger to pry open the plastic clips that secure the outer case.
  2. JBL Flip 5 Buttons Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Once all the clips are released, you will be able to pull up that edge of the case.
  3. JBL Flip 5 Buttons Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Once one side is released, complete the previous two steps with the other side.
    • This side contains the buttons, so be careful so as to not damage them while prying the case off.
  4. JBL Flip 5 Buttons Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 JBL Flip 5 Buttons Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Once all the clips are removed, you can gently remove the outer case.
    • The case is now fully removed. Now a new case will be attached by putting the case into position and pushing on the clips to reattach them.
  5. JBL Flip 5 Buttons Replacement, Speaker: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Begin by unscrewing the four 9.6 mm-long screws with the Philips #00 screwdriver.
    • Make sure to be careful with the gasket under the edges!
  6. JBL Flip 5 Buttons Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Once screws are fully out make sure to carefully pull out so the wires connected don't get damaged.
  7. JBL Flip 5 Buttons Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Once you carefully lift up the speaker, gently disconnect the wire that connects the speaker to the motherboard.
    Somebody can tell me what type of the ribbon cable is that? Is connection between mother board and the turn on/off, bluetooth and party mode.
    I need all the information about that ribbon.
    Andrei Loghin - crwdns2934203:0crwdne2934203:0
  8. JBL Flip 5 Buttons Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Once connection has been disconnected you can lift the speaker completely out.
  9. JBL Flip 5 Buttons Replacement, Buttons: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 JBL Flip 5 Buttons Replacement, Buttons: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 JBL Flip 5 Buttons Replacement, Buttons: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The next part needed to remove covers each side and the power and bluetooth buttons in a middle strip along the speaker.
    • The first picture is for reference. That is the part that will be removed.
    • Begin (as shown in the second picture) by unscrewing the two screws (17mm each) with the Philips #00 screwdriver.
    • Then flip the device around and unscrew the other two screws (17 mm each) on the other side just the same.
    • In these pictures the speaker is still in the device. It is best to have already removed it in the Speaker Replacement Guide.
  10. JBL Flip 5 Buttons Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 JBL Flip 5 Buttons Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Once all the screws are removed, pull the passive radiator bracket on either end off.
    • Set the passive radiator bracket to the side. It is not needed for the buttons replacement.
  11. JBL Flip 5 Buttons Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 JBL Flip 5 Buttons Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 JBL Flip 5 Buttons Replacement: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Next you must remove the passive radiator.
    • To do so use the metal spudger to undo the clips holding it down.
    • Once the clips on both sides are removed, you can pull the left and right passive radiators off the device.
    • Both can be set aside. They are not needed for the buttons replacement.
  12. JBL Flip 5 Buttons Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 JBL Flip 5 Buttons Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Once the speaker is removed, you must go in through the hole where the speaker was for this step.
    • There you can use tweezers or your fingers to unhook the connection of the buttons board to the rest of the device.
  13. JBL Flip 5 Buttons Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 JBL Flip 5 Buttons Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Peel the rubber cover off using a metal spudger. It may be very sticky, so you may need to pull hard.
    • Then peel the cover off using your fingers.
  14. JBL Flip 5 Buttons Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 JBL Flip 5 Buttons Replacement: crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Again use the spudger to pull the buttons board off.
    • It is glued down, so you must be very assertive using the spudger.
  15. JBL Flip 5 Buttons Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 JBL Flip 5 Buttons Replacement: crwdns2935265:015crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • In these photos, the buttons board is still on.
    • If only certain buttons are not working it may be appropriate to only replace the buttons board with play/pause and volume up/down. If you are having trouble with the power and bluetooth buttons as well, this step will allow you to replace those.
    • Use the metal spudger to again pull the board containing the power and bluetooth buttons off from the device. It is located next to the strap.
    • It's glued on, use necessary force.
Jackson Tillinghast
crwdns2935283:010/30/23crwdne2935283:0
327 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team 3-5, Konn Fall 2023 crwdns2935289:0UMass Dartmouth, Team 3-5, Konn Fall 2023crwdne2935289:0
UMASSD-KONN-F23S3G5
I think the newer JBL Flip 5 speakers have updated internals. I received a Flip 5 as a gift years ago and recently had to replace the battery using the tutorials on this website, and it went off without a hitch. I decided to buy another Flip 5 to use the party feature; I accidentally dropped it, and the buttons on the side stopped working. This is when I found out that the internals of my two JBL Flip 5 speakers looked different. This is only my second time trying to repair something on my own, any suggestions would be greatly appreciated.
Jahvier Temple - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 75
crwdns2942667:0crwdne2942667:0 956
