JBL Flip 4 cable for buttons Replacement
  1. JBL Flip 4 cable for buttons Replacement, remove adhesive: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • remove all adhesive tapes / sticker inside (above the cables).
    • Take care of other sensitive cables.
  2. JBL Flip 4 cable for buttons Replacement, Unlock cables: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 JBL Flip 4 cable for buttons Replacement, Unlock cables: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 JBL Flip 4 cable for buttons Replacement, Unlock cables: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Flip open the top flap on the ZIF connectors (the grey part):
    • Use the tip of a spudger or your fingernail to flip up the small, hinged locking flap on the cable ZIF connectors.
    • Use a pair of tweezers to pull the cable out of the ZIF connectors.
  3. JBL Flip 4 cable for buttons Replacement, Open both rubber cover (a bit): crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 JBL Flip 4 cable for buttons Replacement, Open both rubber cover (a bit): crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert the plastic opening tool under the clear rubber cover over the button control board.
    • Pry up the cover using the opening tool.
    • Only open a bit (until cable).
    • The cover is glued on so it will take some force to pry up.
  4. JBL Flip 4 cable for buttons Replacement, Unlock cables: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 JBL Flip 4 cable for buttons Replacement, Unlock cables: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flip open the top flap on the ZIF connectors (the grew part).
  5. JBL Flip 4 cable for buttons Replacement, Remove old cables: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The 6 Pin cable have some glue here.
    • Pull the cables out.
  6. JBL Flip 4 cable for buttons Replacement, The new cables: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 JBL Flip 4 cable for buttons Replacement, The new cables: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 JBL Flip 4 cable for buttons Replacement, The new cables: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Buy new cables. These cables are called FFC or FPC flex cable. The distance between the contacts ( called Pitch ) is 0.5mm. Cable length is origin 12 cm (10 cm or 15 cm fits also). More details:
    • Buttons power, led, : 13 Pin - Type A
    • Buttons play, + , - , connect : 6 Pin - Type B (reverse) (=the connectors are reversed to each other)
    • The (blue) inflexible cable-end have to be maximal 0.5 mm long (at least one side). Otherwise you must trim this part: Use tools like cutter & scissors ( see video below ) or alternative a mini rasp / file.
    • read above.
  7. JBL Flip 4 cable for buttons Replacement, insert new: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 JBL Flip 4 cable for buttons Replacement, insert new: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 JBL Flip 4 cable for buttons Replacement, insert new: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
  8. JBL Flip 4 cable for buttons Replacement, Test and fixing: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 JBL Flip 4 cable for buttons Replacement, Test and fixing: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Test it: Reconnect the battery. Check if all buttons are working. Disconnect the battery again.
    • Final: Rolling in cable. Fixing the cable with tape and glue it. ( Put upright for a day, while drying glue (due to glue solvent) )
Joe Musters
crwdns2935283:007/02/20crwdne2935283:0
1.235 crwdns2915208:0crwdne2915208:0
crwdns2936753:07crwdne2936753:0 31
crwdns2936753:030crwdne2936753:0 134
crwdns2942667:0crwdne2942667:0 1,216
