JBL Flip 4 Battery Replacement
    1. JBL Flip 4 Battery Replacement, Shell: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 JBL Flip 4 Battery Replacement, Shell: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 JBL Flip 4 Battery Replacement, Shell: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Insert the plastic opening tool in the crack in between the cover and the rubber spine with the power button.
      • Pry off the cover, beginning with the side without the volume and bluetooth buttons.
      • When prying the cover off, the six clips (three along each side of rubber spine) that attach the cover to the speaker will make snapping sounds.
      • Watch out not to damage the clips on the buttons' side, pry open with caution.
      • Pull the cover off with your thumbs.
    2. JBL Flip 4 Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 JBL Flip 4 Battery Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 JBL Flip 4 Battery Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Remove four 13 mm JIS #0 screws attaching the rubber spine to the speaker, located on both sides of the inside of the speaker.
      • Use the plastic opening tool to release the clips holding the central part of the rubber spine.
      • Pry away one end of the rubber spine with your thumbs and it should come off.
      • Prying off the spine may take some persuading.
      • The speakers are strong magnets. Keep it away from other sensitive electronics.
    1. JBL Flip 4 Battery Replacement, remove cap: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 JBL Flip 4 Battery Replacement, remove cap: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 JBL Flip 4 Battery Replacement, remove cap: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • The end cap opposite to the USB port: Twist - or - remove screws from the cap. (depends on your model-version: only older version have 9mm Phillips #1 screws)
      • Pull the end cap off with your hands.
    2. JBL Flip 4 Battery Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 JBL Flip 4 Battery Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 JBL Flip 4 Battery Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Remove two 11mm Phillips #1 screws on the battery cover.
      • Pull the battery cover off with your hands.
    3. JBL Flip 4 Battery Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 JBL Flip 4 Battery Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 JBL Flip 4 Battery Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Remove the large white plug that connects the wires from the battery to the main board using your hands.
      • Pull the battery out with your hands.
      • If the battery is swollen, you might not be able to pull it out with your hands, you might just rip the cables+charging board out.
      • In this case: You can pushing out the Battery, which we documented in an extra guide.
      • A short preview: You can remove the other radiator, unscrew the charging port and gently pull it out just a bit so a pencil (flat end) can fit in and push out the battery from this side.
      • The port might be hot glued and under the tapes there are very small normal and ribbon cables, so be careful not to cut or rip them.
      • More details and pictures in the separated extra guide.
crwdns2935229:0199crwdne2935229:0
Philip Pang
crwdns2935283:010/08/18crwdne2935283:0
1,461 crwdns2915208:0crwdne2915208:0
Cal Poly, Team S4-G3, White Fall 2018 crwdns2935289:0Cal Poly, Team S4-G3, White Fall 2018crwdne2935289:0
CPSU-WHITE-F18S4G3
crwdns2935297:042crwdne2935297:0
crwdns2947412:080crwdne2947412:0
Is the battery glued into the socket like the Flip 3?
Kenneth - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
No it isn’t. but the black rubber around it makes it really hard to get out. try to push it from the otherside by removing the charging-port.
Be careful not to pierce the battery
Richardo Otros - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Yes with me the battery was glued
Diter Freeman - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Be careful and don’t do like me: my old battery was bloated, so I had to push from the other side, but when doing so, I ripped the ribbon cable from the power button… now trying to find a replacement cable
jmbarroso - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Did you find the cable of the power button?
mohamed da - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936751:024crwdne2936751:0 78
crwdns2936753:07crwdne2936753:0 488
crwdns2936753:030crwdne2936753:0 2,136
crwdns2942667:0crwdne2942667:0 294,409
