JBL Clip Plus Microphone Replacement
crwdns2942287:0crwdne2942287:0This guide will focus on removing the microphone.
crwdns2944105:0crwdne2944105:0
crwdns2935267:0crwdne2935267:0Tweezers$3.99
Use the angled tweezers to carefully pull the rubber bumper off the back side of the device
There will be three 6mm philips head screws under that rubber bumper, remove these three screws.
The back cover should lift open easily and the components should be visible.
The battery is adhered to the back cover of the JBL Clip Plus, slowly lift the battery away from the case, using a spudger to pry the battery away from the adhesive.
Remove the three 7mm philips head screws on the outer edges of the device.
Use the plastic prying tool to gently remove the face of the speaker from the body.
Use the spudger tool to gently scrape away the adhesive holding in the microphone.
Gently push the motherboard away from the microphone, this will allow you to remove the microphone.
Gently push the motherboard out from the frame of the JBL Clip Plus, this requires some force.
There are three solder points that need to be desoldered.
If you need help with desoldering refer to How to Solder and Desolder Connections help. After these are removed the battery should be free.
Its easy to cut wires then connect new battery using solderless connectors.
Could you post the dimensions of the battery (L xW x H) so i can replace it with generic ones from China. cheers
Nice job. Wasn't able to use the same battery though. I just used something that I could find in a local electronic shop near home and made renovations to the battery housing for it to fit. Thanks you!
Use a desolder tool to remove the solder to the microphone.
If you are unsure how to desolder these connections, refer to How To Solder and Desolder Connections
Love the sound of this speaker but I would like to disable the bluetooth signals. I only need and use the cable connection. I have contacted the manufacturer about this and they said the bluetooth cannot be disabled at the present set-up. Would you please show me how to disable or remove the bluetooth?
