JBL Charge 5 Charging Port Assembly Replacement
  1. JBL Charge 5 Charging Port Assembly Replacement, Fabric Case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 JBL Charge 5 Charging Port Assembly Replacement, Fabric Case: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 JBL Charge 5 Charging Port Assembly Replacement, Fabric Case: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Ensure that the device is fully powered off and no cables are attached before proceeding with the repair.
    • This fabric cover is secured with plastic clips only. Depending on the model, the cover may be secured by both plastic clips and screws.
    • Insert the flat end of the Jimmy into the seam located between the fabric cover on the right side of the seam.
    • Pry upward on the fabric cover to release plastic clips on the right side of the seam.
  2. JBL Charge 5 Charging Port Assembly Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 JBL Charge 5 Charging Port Assembly Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 JBL Charge 5 Charging Port Assembly Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert the flat end of the Jimmy into the seam between the fabric cover at the center of the seam and the left side of the seam.
    • Use the Jimmy to pry open the edge with the rubber texture, releasing the remaining plastic clips.
  3. JBL Charge 5 Charging Port Assembly Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 JBL Charge 5 Charging Port Assembly Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 JBL Charge 5 Charging Port Assembly Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use your hands to gently open the two halves of the casing and slide the fabric cover off of the interior housing.
  4. JBL Charge 5 Charging Port Assembly Replacement, Charging Port Assembly: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 JBL Charge 5 Charging Port Assembly Replacement, Charging Port Assembly: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 JBL Charge 5 Charging Port Assembly Replacement, Charging Port Assembly: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a Phillips #0 screwdriver to remove the four 10.6 mm screws on the charging port cover.
  5. JBL Charge 5 Charging Port Assembly Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 JBL Charge 5 Charging Port Assembly Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 JBL Charge 5 Charging Port Assembly Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the opening tool or spudger to undo the clips.
    • Do not immediately remove the charging port.
  6. JBL Charge 5 Charging Port Assembly Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 JBL Charge 5 Charging Port Assembly Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 JBL Charge 5 Charging Port Assembly Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Rotate the device to the left, and push the left passive bass radiator off of the frame of the device using the metal spudger.
  7. JBL Charge 5 Charging Port Assembly Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 JBL Charge 5 Charging Port Assembly Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 JBL Charge 5 Charging Port Assembly Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pinch the charging port connector and gently remove the blue and black no-fuss ribbon cable from the board.
    • Pinch the connector with both fingers when removing it to ensure the ribbon cable will not tear.
  8. JBL Charge 5 Charging Port Assembly Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 JBL Charge 5 Charging Port Assembly Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 JBL Charge 5 Charging Port Assembly Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using both fingers, remove the charging port assembly.
Kat Whaley
crwdns2935283:009/13/23crwdne2935283:0
870 crwdns2915208:0crwdne2915208:0
Western Carolina University, Team 1-2, Virtue Fall 2023 crwdns2935289:0Western Carolina University, Team 1-2, Virtue Fall 2023crwdne2935289:0
WCU-VIRTUE-F23S1G2
crwdns2936753:07crwdne2936753:0 22
crwdns2936753:030crwdne2936753:0 103
crwdns2942667:0crwdne2942667:0 1,830
