JBL Charge 4 Passive Bass Radiators Replacement
  1. JBL Charge 4 Passive Bass Radiators Replacement, Speaker Grill: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flip your speaker over and insert the plastic opening tool into the slit on the grille.
    • Pry away from yourself towards the back of the speaker to release the clip.
    • Repeat this process for the clip on the other side.
    ich schaffe es nur auf der einen seite. Auf der anderen ist die abdeckung viel zu fest dran ? was kann ich machen ?
    George Ziakos - crwdns2934203:0crwdne2934203:0
  2. JBL Charge 4 Passive Bass Radiators Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 JBL Charge 4 Passive Bass Radiators Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the two 8mm Phillips #0 screws from the other edge of the grille.
    You have to remove the 8 mm screws before you try and Prius the other side. They are attached, and will break
    Noah Werthaiser - crwdns2934203:0crwdne2934203:0
  3. JBL Charge 4 Passive Bass Radiators Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull apart both sides of the grille.
    • Lift the cover off of the speaker.
  4. JBL Charge 4 Passive Bass Radiators Replacement, Passive Bass Radiators: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 JBL Charge 4 Passive Bass Radiators Replacement, Passive Bass Radiators: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using the plastic opening tool, lift the tab on top of the speaker to release the radiator from the clips.
    • Repeat this process on the other clips around the radiator to release it from the frame.
    There is absolutely no reason to remove the passive radiators if you want to replace the speaker only!
    Just cut to step 6.
    Also the difficulty level is way too high. I found it very easy to disassemble the unit.
    Paul Decaro - crwdns2934203:0crwdne2934203:0
  5. JBL Charge 4 Passive Bass Radiators Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 JBL Charge 4 Passive Bass Radiators Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Push the radiator off of the frame of the device.
    • Repeat on the other side.
    • The passive bass radiators seal out water from inside the device. Removing them multiple times may compromise the waterproof nature of the speaker.
crwdns2935229:09crwdne2935229:0
Zachary Colwell
crwdns2935283:001/24/19crwdne2935283:0
2,031 crwdns2915208:0crwdne2915208:0
Cal Poly, Team S1-G1, White Winter 2019 crwdns2935289:0Cal Poly, Team S1-G1, White Winter 2019crwdne2935289:0
CPSU-WHITE-W19S1G1
crwdns2935297:027crwdne2935297:0
crwdns2947412:05crwdne2947412:0
Exactly where are supposed to get parts for this, do you suppose !?
Yash Bhushan - crwdns2934203:0crwdne2934203:0
It says it on the top of the introduction
Jacob Galeano Garcia -
Hi do you hany any suggestion on where to buy the passive radiators?
Epolu Isaac Tushabe - crwdns2934203:0crwdne2934203:0
Were can i get the main cover from can you help please and the subwoofers
Nate Millette - crwdns2934203:0crwdne2934203:0
Yo tengo la charge 4 y se me rompió uno de los radiadores lo que yo quisiera saber si se pueden arreglar o lo tengo que cambiar por otro
Reynaldo Ronquillo - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 66
crwdns2942667:0crwdne2942667:0 7,639
