JBL Charge 4 Battery Replacement
  1. JBL Charge 4 Battery Replacement, Speaker Grill: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flip your speaker over and insert the plastic opening tool into the slit on the grille.
    • Pry away from yourself towards the back of the speaker to release the clip.
    • Repeat this process for the clip on the other side.
  2. JBL Charge 4 Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 JBL Charge 4 Battery Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the two 8mm Phillips #0 screws from the other edge of the grille.
  3. JBL Charge 4 Battery Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull apart both sides of the grille.
    • Lift the cover off of the speaker.
  4. JBL Charge 4 Battery Replacement, Passive Bass Radiators: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 JBL Charge 4 Battery Replacement, Passive Bass Radiators: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using the plastic opening tool, lift the tab on top of the speaker to release the radiator from the clips.
    • Repeat this process on the other clips around the radiator to release it from the frame.
  5. JBL Charge 4 Battery Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 JBL Charge 4 Battery Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Push the radiator off of the frame of the device.
    • Repeat on the other side.
    • The passive bass radiators seal out water from inside the device. Removing them multiple times may compromise the waterproof nature of the speaker.
  6. JBL Charge 4 Battery Replacement, Battery: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 JBL Charge 4 Battery Replacement, Battery: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the two 6mm Phillips #0 screws on the front side of the port bay cover.
  7. JBL Charge 4 Battery Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently slide the cover back and off the hooks.
    • Remove the port bay cover.
  8. JBL Charge 4 Battery Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 JBL Charge 4 Battery Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 JBL Charge 4 Battery Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the two 6mm Phillips #0 screws.
    • Remove the four 8mm Phillips #0 screws.
  9. JBL Charge 4 Battery Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift up the battery cover.
  10. JBL Charge 4 Battery Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 JBL Charge 4 Battery Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 JBL Charge 4 Battery Replacement: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the sticky tape to expose the white ribbon cable ZIF connector.
    • Flip up the black locking flap on the ZIF connector with the tip of a spudger or your fingernail to release the cable.
    • Remove the white ribbon cable from the battery cover and place the cover to the side.
  11. JBL Charge 4 Battery Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 JBL Charge 4 Battery Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the battery from the battery socket by gently pulling on it.
  12. JBL Charge 4 Battery Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 JBL Charge 4 Battery Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 JBL Charge 4 Battery Replacement: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull out the battery enough to expose the battery's wire connector.
    • Push down on the white tab and gently pull out the battery-device connector.
crwdns2935229:024crwdne2935229:0
Sydney Seto
crwdns2935283:001/24/19crwdne2935283:0
867 crwdns2915208:0crwdne2915208:0
Cal Poly, Team S1-G1, White Winter 2019 crwdns2935289:0Cal Poly, Team S1-G1, White Winter 2019crwdne2935289:0
CPSU-WHITE-W19S1G1
crwdns2935297:029crwdne2935297:0
crwdns2947412:017crwdne2947412:0
Where do you buy a battery for a jbl Charge 4 ??
Matt hempel - crwdns2934203:0crwdne2934203:0
Probably just cut open the blue foil around the batteries and replace them by re-soldering the electronics onto new 18650 batteries.
correct me if I’m wrong here.
Brendon Reijnders -
If you know how to handle them and have experience with soldering them that's a yes if not those batteries are really dangerous if you don't know how to do it correctly.
Hart80 -
Where in the !&&* do i get a battery for a bluetooth speaker. What happened to the jbl charge 4 that it even goes out???
Shani Sanders - crwdns2934203:0crwdne2934203:0
My JBL charge 4 battery dead too. 9nly uses it for three months
osborne buhere - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 19
crwdns2936753:07crwdne2936753:0 150
crwdns2936753:030crwdne2936753:0 678
crwdns2942667:0crwdne2942667:0 78,523
