Iomega Z100S2 Disk Reader Replacement
Push in the plastic tab that can be seen through cracks in the front left corner using a spudger.
Move down the same side and push in the plastic tab.
Move to the front right side and once again push in the plastic tab.
Grab the cover by the front side and pull upwards.
You might encounter some resistance. Pull firmly, but don't yank it.
Tilt the front case down until the pegs detach from the bottom of the case.
Lift up and outward.
Easy button and status light repair:
button and plastic piece both need just 2 tiny drops of super glue.
Unhook the two springs from the front plastic hooks.
There is a white tab connected to the motherboard. Pull it upward by gently rocking it back and forth.
Grab the reader by its sides and gently pull it upward.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Disconnect the white wires by using tweezers to gently pull the bottom connector toward you.
Disconnect the thin ribbon wire by using tweezers to gently pull the connector at the bottom toward you.
Lift the reader up and out from the device.
crwdns2935229:05crwdne2935229:0
Great guide exactly what I was looking for.
Zip disks were awesome, and they still are they fit that niche between needing something small in capacity but not large enough for a USB flash drive.
