crwdns2935175:0crwdne2935175:0 – crwdns2935177:0crwdne2935177:0
  1. Intertek Clip Fan 0610 Teardown, Familiarize Yourself with the Clip Fan: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Intertek Clip Fan 0610 Teardown, Familiarize Yourself with the Clip Fan: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Intertek Clip Fan 0610 Teardown, Familiarize Yourself with the Clip Fan: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • There are 5 main parts of the fan:
    • Fan blade (red circle)
    • Cage (blue arrow)
    • Clip (green arrow)
    • Fan Speed Switch (orange box)
    • Swivel Lock (pink circle)
  2. Intertek Clip Fan 0610 Teardown, Removing the Fan Body from the Clip: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Intertek Clip Fan 0610 Teardown, Removing the Fan Body from the Clip: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Intertek Clip Fan 0610 Teardown, Removing the Fan Body from the Clip: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • To begin, place the fan face down. Start loosening the swivel lock by rotating counter clockwise.
    • Once the swivel lock is fully separated from the clip and fan body, place the nut and the screw of the swivel lock to the side in a safe location.
  3. Intertek Clip Fan 0610 Teardown, Remove the Cage from the Fan Body: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Intertek Clip Fan 0610 Teardown, Remove the Cage from the Fan Body: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Intertek Clip Fan 0610 Teardown, Remove the Cage from the Fan Body: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Locate the 5 plastic fasteners, indicated by the red arrows, which keep the cage connected to the fan body.
    • Unlatch each fastener by leveraging the metal spudger between the plastic casing and the cage. Stretch the plastic casing out until the fastener is pulled away from the cage, and pull the cage up and over the fastener.
    • Once all 5 fasteners are unlatched, pull the cage off of the fan body.
  4. Intertek Clip Fan 0610 Teardown, Removing the Fan Blade from the Fan Body: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Intertek Clip Fan 0610 Teardown, Removing the Fan Blade from the Fan Body: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Intertek Clip Fan 0610 Teardown, Removing the Fan Blade from the Fan Body: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Grab the center of the fan blade and pull up from the body until it is separated. Once the blade is removed, it can be cleaned and maintained.
  5. Intertek Clip Fan 0610 Teardown, Opening the Fan Body to Access the Motor: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Intertek Clip Fan 0610 Teardown, Opening the Fan Body to Access the Motor: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Intertek Clip Fan 0610 Teardown, Opening the Fan Body to Access the Motor: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • To begin, place the fan body face down and locate the Phillips #2 screw on the back plate (circled in red).
    • Unscrew using a Phillips #2 screwdriver and store the screw in a safe location.
    • Pull the back plate casing up from the fan body to access the motor.
  6. Intertek Clip Fan 0610 Teardown, Unscrewing the Power Cord Fastener: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Intertek Clip Fan 0610 Teardown, Unscrewing the Power Cord Fastener: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Intertek Clip Fan 0610 Teardown, Unscrewing the Power Cord Fastener: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Locate the Phillips #2 screw within the motor casing that fastens the power cord.
    • Using a Phillips #2 screwdriver, unscrew and store the screw in a safe location.
  7. Intertek Clip Fan 0610 Teardown, Removing the Motor from the Fan Body: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Intertek Clip Fan 0610 Teardown, Removing the Motor from the Fan Body: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Intertek Clip Fan 0610 Teardown, Removing the Motor from the Fan Body: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Next, locate the two Phillips #2 screws which secure the motor to the casing (circled in red).
    • Unscrew using a Phillips #2 screwdriver and store the screws in a safe location.
    • Grab the motor on each end and pull up and out of the casing. Note that the power cord will need to be pulled further through the casing hole in order to pull the motor completely out.
  8. Intertek Clip Fan 0610 Teardown, Removing the Switch from the Back Plate: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Intertek Clip Fan 0610 Teardown, Removing the Switch from the Back Plate: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Intertek Clip Fan 0610 Teardown, Removing the Switch from the Back Plate: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Next, locate the two Phillips #2 screws which fasten the switch to the back plate (circled in red).
    • Pull the switch away from the back plate. Once the backplate is removed, maintenance and cleaning can take place.
    • Note: when reassembling the switch to the back plate, ensure that the switch is facing the right direction in order to match the High and Low speed back plate markings with the actual High and Low speeds of the switch.
  9. Intertek Clip Fan 0610 Teardown, Reassembling the Fan: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • To reassemble the fan, follow the previous steps in reverse order.
DJ Alexander
crwdns2935283:004/17/17crwdne2935283:0
169 crwdns2915208:0crwdne2915208:0
Cal Poly, Team S15-G1, Banghart Spring 2017 crwdns2935289:0Cal Poly, Team S15-G1, Banghart Spring 2017crwdne2935289:0
CPSU-BANGHART-S17S15G1
crwdns2942667:0crwdne2942667:0 4,464
