(Windows) Installing a HP LaserJet Printer using the HP UPD
  1. (Windows) Installing a HP LaserJet Printer using the HP UPD, Research - Check what personalities your printer uses: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 (Windows) Installing a HP LaserJet Printer using the HP UPD, Research - Check what personalities your printer uses: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 (Windows) Installing a HP LaserJet Printer using the HP UPD, Research - Check what personalities your printer uses: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Authors note: Any REASONABLY NEW laser printer supports PCL6 as a general rule (but confirm with the spec sheet!). However, some older monochrome lasers (and early low end color models, such as the CLJ CP1025) often have limited RAM (often 64MB OR LESS). This can result in "PCL personality error" pages, which clear with a power cycle.
    • Due to the general nature of this guide, specific languages are not covered. The HP UPD supports PCL6 and PostScript.
    • Find out what print languages your printer supports. The LaserJet Pro M401 series supports PCL6 and PostScript. However, PCL6 is recommended when possible.
    • Get your printer ready for setup. If you use USB, connect the printer now. If networked, make sure to get your printers IP address now as it will be needed later on.
  2. (Windows) Installing a HP LaserJet Printer using the HP UPD, Download the HP UPD driver: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 (Windows) Installing a HP LaserJet Printer using the HP UPD, Download the HP UPD driver: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • I knew what my printer used in advance. Yours may have minor variations.
    • Once you know what print language(s) your printer supports, download the best one for your printer. The driver can be found on the HP website.
  3. (Windows) Installing a HP LaserJet Printer using the HP UPD, Driver installation (USB/LAN) - Manual setup required: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 (Windows) Installing a HP LaserJet Printer using the HP UPD, Driver installation (USB/LAN) - Manual setup required: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 (Windows) Installing a HP LaserJet Printer using the HP UPD, Driver installation (USB/LAN) - Manual setup required: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • While Windows 7 is being shown here, the same steps apply in Windows 10 and 11.
    • This method can be used for USB printing or network printing but requires manual setup, as it copies the files to the computer in the Windows driver folder. This can be used in place of model-specific drivers, which can sometimes work around bugs that come up as the printer ages
    • At the installation screen, select USB mode- Plug and Play.
    • Once you select the mode, pick the options you wish to use. While these settings can be changed, leave it as-is unless you understand what this does to the Windows driver store.
    • Click Next and the files will be copied to your computer.
  4. (Windows) Installing a HP LaserJet Printer using the HP UPD, Dynamic Mode - Driver installation: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 (Windows) Installing a HP LaserJet Printer using the HP UPD, Dynamic Mode - Driver installation: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 (Windows) Installing a HP LaserJet Printer using the HP UPD, Dynamic Mode - Driver installation: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • This installation method only works with networked printers. USB IS NOT SUPPORTED.
    • After the driver loads, agree to the license.
    • Once you agree to the license, you will be asked which installation mode you want to use. Select Dynamic Mode and click Next.
    • After selecting Dynamic Mode, click Next. The printer driver will be installed alongside a "universal printer".
    • Once the driver is installed, manual configuration and a static IP address on the printer are REQUIRED. The printer is configured via IP address with this method.
  5. (Windows) Installing a HP LaserJet Printer using the HP UPD, Dynamic Mode - adding a printer: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 (Windows) Installing a HP LaserJet Printer using the HP UPD, Dynamic Mode - adding a printer: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 (Windows) Installing a HP LaserJet Printer using the HP UPD, Dynamic Mode - adding a printer: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Select a file to print and select the HP Universal Printing PCL6 "printer". A box to select a printer will immediately pop on your screen.
    • Once the HP printer queue comes up, select Add a printer address or Search for printer addresses and enter the IP address setup on your printer, if you enter the IP address manually.
    • Manual IP entry only Enter the IP address and click Ok. The printer will now be added.
  6. (Windows) Installing a HP LaserJet Printer using the HP UPD, (Windows 10/11) - Accessing the legacy control panel: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 (Windows) Installing a HP LaserJet Printer using the HP UPD, (Windows 10/11) - Accessing the legacy control panel: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 (Windows) Installing a HP LaserJet Printer using the HP UPD, (Windows 10/11) - Accessing the legacy control panel: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Microsoft has largely retired the control panel since WIndows 11 24H2, and no longer work in Wndows 11 - these only work in Windows 10 (EOL, but eligible for Consumer ESUs) or 23H2 and older for 11. You must use the control panel, or God Mode in place of the legacy control panel. Select "Advanced printer setup" if you use God Mode.
    • In the search bar, search for Control panel. This will open the legacy control panel on Windows 10 and 11.
    • Select Devices and Printers (Icon View) or View Devices and Printers (Category View), and then you will see the option in the top bar that says Add a Printer. Select this option, and pick the appropriate option for your specific printer.
  7. (Windows) Installing a HP LaserJet Printer using the HP UPD, Windows 11 24H2+ - accessing manual setup (Control panel): crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 (Windows) Installing a HP LaserJet Printer using the HP UPD, Windows 11 24H2+ - accessing manual setup (Control panel): crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 (Windows) Installing a HP LaserJet Printer using the HP UPD, Windows 11 24H2+ - accessing manual setup (Control panel): crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • These steps are for Windows 11 24H2+ and legacy versions which you choose to use the control panel.
    • On the left side (not shown), click on Bluetooth & devices. Once this is done, click on Printers & scanners.
    • Click on Add device. Wait a few minutes and click on Add a new device manually.
    • Previous steps apply as they did in Win7 and older. Setup your legacy printer as normal.
  8. (Windows) Installing a HP LaserJet Printer using the HP UPD, Windows 11 24H2+ - God Mode: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 (Windows) Installing a HP LaserJet Printer using the HP UPD, Windows 11 24H2+ - God Mode: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 (Windows) Installing a HP LaserJet Printer using the HP UPD, Windows 11 24H2+ - God Mode: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • After setting up God Mode, click on the blank shortcut.
    • Scroll down to Devices and Printers and select Advanced printer setup.
    • Select My printer isn't listed if needed - most super old models will require this, but some newer models might show up on the initial query.
  9. (Windows) Installing a HP LaserJet Printer using the HP UPD, Manual Setup - Printer configuration: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 (Windows) Installing a HP LaserJet Printer using the HP UPD, Manual Setup - Printer configuration: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 (Windows) Installing a HP LaserJet Printer using the HP UPD, Manual Setup - Printer configuration: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Manual configuration is required when using the HP UPD to replace failing legacy drivers on printers setup using a USB cable. These older printers use "USB_001" or "DOT4" depending on the age of the printer. (IMPORTANT: most of the older bulletproof models like the 1012, 1200, 4200 and 4300 series are old enough to require "DOT4")
    • Find Devices and Printers. The location will vary based on what version of Windows is installed. Search for Control panel and find Devices and Printers.
    • Click Add a Printer. If your printer uses USB, select Add a Local printer. For networked printers, select Add a Network, Wireless, or Bluetooth printer.
    • Allow your computer to populate the driver list. Find HP and then locate the driver that says HP Universal Printing (PCL6/PostScript). Select the driver and click Next.
    • Name your printer, then click Next.
  10. (Windows) Installing a HP LaserJet Printer using the HP UPD, Print a test page: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 (Windows) Installing a HP LaserJet Printer using the HP UPD, Print a test page: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 (Windows) Installing a HP LaserJet Printer using the HP UPD, Print a test page: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • After the printer is installed, print a test page to make sure it works. Click Print a test page and make sure it works.
Nick
crwdns2935283:011/10/09crwdne2935283:0
97,339 crwdns2915208:0crwdne2915208:0
crwdns2935297:061crwdne2935297:0
I bought an HP printer specified by laserjet. I have followed a few steps to install this printer via HP UPD. at first search for the correct driver, then install it first in a USB mode after that in dynamic mode. then set the configuration pf printer and after completing all the steps just print once for a test.
www.facebook.com
jolly stark - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 19
crwdns2936753:030crwdne2936753:0 121
crwdns2942667:0crwdne2942667:0 10,597
