Inspiron 7359 2-in-1 Hard Disk Drive Replacement
  1. Inspiron 7359 2-in-1 Hard Disk Drive Replacement, Bottom Case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Turn off device before starting.
    • Turn the laptop upside down with the logo facing the surface of the table.
  2. Inspiron 7359 2-in-1 Hard Disk Drive Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Inspiron 7359 2-in-1 Hard Disk Drive Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips #0 screwdriver to remove the ten 8mm screws from the back case of the laptop.
  3. Inspiron 7359 2-in-1 Hard Disk Drive Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a spudger to separate the back cover from the laptop.
    • Start from one corner and work your way around the edge of the cover.
    • Be careful not to bend or crack the back cover.
  4. Inspiron 7359 2-in-1 Hard Disk Drive Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • All hardware components should be exposed.
  5. Inspiron 7359 2-in-1 Hard Disk Drive Replacement, Hard Disk Drive: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unscrew three 3mm screws with a Phillips #0 screwdriver and remove them.
    • These screws hold the hdd and removing these screws will make it easier to remove it.
  6. Inspiron 7359 2-in-1 Hard Disk Drive Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Inspiron 7359 2-in-1 Hard Disk Drive Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the hard drive from the left side. Be careful not pull on it.
    • Pull the SATA cable that's connect to the hard drive and then carefully place the cable on the side.
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
meetkumar desai
crwdns2935283:010/08/17crwdne2935283:0
330 crwdns2915208:0crwdne2915208:0
Gateway, Team S1-G3, Saknee Fall 2019 crwdns2935289:0Gateway, Team S1-G3, Saknee Fall 2019crwdne2935289:0
GCC-SAKNEE-F19S1G3
crwdns2942667:0crwdne2942667:0 288
