Insignia Flex 10.1 NS-P10W8100 Battery Replacement
  1. Insignia Flex 10.1 NS-P10W8100 Battery Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Insignia Flex 10.1 NS-P10W8100 Battery Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Carefully open the laptop and remove the keyboard by disconnecting it.
    • Place keyboard to the side as you will not need it.
    • Beware of plastic clips on the side of the device.
    Hello im here just because this exact model of tablet that i have has its battery depleted and wont turn on or even if the cord is connected theres no signs of charging. I wanna know the model of this battery so i can replace the depleted one i cant seem to find any battery in stock with this model.
    Keanejedrick Cambarijan - crwdns2934203:0crwdne2934203:0
  2. Insignia Flex 10.1 NS-P10W8100 Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Insignia Flex 10.1 NS-P10W8100 Battery Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lay the screen flat on its surface and use the iFixit opening tool to remove the cover by gently prying the back cover from the screen.
    • Apply the opening tool to the edge closest to the screen.
    • Apply the opening tool to each side which will help pry the back cover evenly.
    • Do not pry on the bottom side of the device. This is the side across from the camera.
  3. Insignia Flex 10.1 NS-P10W8100 Battery Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use your fingers and pry the back cover from the screen. You may need to wiggle the cover a bit to separate the pieces.
    • If the back cover does not come off, work your fingers around the corners and slowly pry the cover off using your fingers.
    • Be careful with potential sharp edges and any exposed electrical components.
  4. Insignia Flex 10.1 NS-P10W8100 Battery Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Insignia Flex 10.1 NS-P10W8100 Battery Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unplug the power supply by disconnecting the red and blue wires found on the motherboard.
  5. Insignia Flex 10.1 NS-P10W8100 Battery Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the black tape from the Zero Insertion Force (ZIF) ribbon connector.
  6. Insignia Flex 10.1 NS-P10W8100 Battery Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Insignia Flex 10.1 NS-P10W8100 Battery Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift up on the black locking flap, being careful not to damage the surrounding hardware parts.
    • Remove the ZIF ribbon wire by pulling horizontally towards the battery.
  7. Insignia Flex 10.1 NS-P10W8100 Battery Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the black tape from the small ribbon wire connector.
    • Pull the ribbon connector out of the plug the same way that was mentioned in step 4.
  8. Insignia Flex 10.1 NS-P10W8100 Battery Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the spudger to separate the battery from the base.
    • The battery can be difficult to remove as it is held in with double sided tape.
    • Be sure not to pry on the battery too hard because damage to the screen and/or the battery can occur.
Edgar Rodriguez
crwdns2935283:002/12/19crwdne2935283:0
1.013 crwdns2915208:0crwdne2915208:0
Western Carolina University, Team S1-G2, Virtue Spring 2019 crwdns2935289:0Western Carolina University, Team S1-G2, Virtue Spring 2019crwdne2935289:0
WCU-VIRTUE-S19S1G2
Very concise and helpful. Thank you
Frank Schaffer - crwdns2934203:0crwdne2934203:0
where can i buy the replacement battery?
José Porras - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 1,269
