Inse N500 Motor Replacement
crwdns2942287:0crwdne2942287:0If your Inse vacuum (model N500) is producing strange noises due to dust and debris in the motorhead, use this repair guide for the motor replacement.
Unclip the plastic band from the vacuum head.
Remove six 6 mm screws using a Phillips #0 screwdriver.
Remove the ten 4 mm screws using a Phillips #0 screwdriver.
Maybe add circle indicators, because in the photo there's 5 holes.
No, there s not. And 4 on front.
Remove the single 4 mm screw from the circuit board using a Phillips #0 screwdriver.
Unfasten the surrounding motor clips and remove the motor.
Please 🙏 the motor of roborock h7 please 🙏
