If your Inse vacuum (model N500) is experiencing reduced runtime, failure to hold a charge, or a decline in suction power, use this guide for battery replacement. Specific to cordless vacuum cleaners, an interchangeable battery is necessary for consistent performance.
Note: Be sure that the vacuum is physically powered off before starting any procedures.
Caution: Swollen/punctured batteries can cause potentially hazardous.
Press the battery pack release button.
Remove the battery from the housing compartment.
This is not the answer to the problem. The problem-battery is not holding the charge-should have a different answer.
No points for you. Any child can change a battery
How much are batteries and where you get them at
