Innioasis Y1 SD Card Replacement
  1. Innioasis Y1 SD Card Replacement, Open The Case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Innioasis Y1 SD Card Replacement, Open The Case: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Innioasis Y1 SD Card Replacement, Open The Case: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a pry tool and start half way up the left or right side of the MP3 player, working your way around the edge
    • Carefully lift the cover off and detach the connecting cable
  2. Innioasis Y1 SD Card Replacement, Remove the Main Board: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Innioasis Y1 SD Card Replacement, Remove the Main Board: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Innioasis Y1 SD Card Replacement, Remove the Main Board: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the 3 screws with a Philips #00
    • Carefully remove the Speak from its clasps with a pry tool
    • Carefully lift the board on the left side with the pry tool
  3. Innioasis Y1 SD Card Replacement, Flip the Board: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Innioasis Y1 SD Card Replacement, Flip the Board: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Innioasis Y1 SD Card Replacement, Flip the Board: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Carefully Lift the board up and towards the screen. You may need to lightly pry the battery out of its socket
    • Remove the tape
    • Slide the Micro SD card out of the socket
Dan
crwdns2935283:002/18/19crwdne2935283:0
4,538 crwdns2915208:0crwdne2915208:0
crwdns2947412:07crwdne2947412:0
Tired of waiting for a reaction to my questions above I bought a Samsung 512GB Micro SD Evo Plus UHS-I U3 SDcard. Maybe overkill, but very fast. the replacement of the card was a 5 minutes job. Now I am copying the contents of the old 128GB card to the Innioasis Y3 which will take hours I guess. I let everyone know if it all works fine.
P. Reuvers - crwdns2934203:0crwdne2934203:0
It works great. Only one small issue. The Innioasis Y1 shows that it contain 128GB, But he shows the correct used and available space, at this moment I used 143GB of the 512GB, more then the original Innioasis Y1.
P. Reuvers -
Any suggestion on how to format the SD Card? thanks
Paninaro -
Will this work with an ExFAT format card or just FAT32? Thanks
jjedwards894 - crwdns2934203:0crwdne2934203:0
ExFAT worked fine for me.
Tanner Mills -
Thanks Bud! Worked great. Getting the case open was trickier than I expected. Otherwise it's even easier once the screws are out of the motherboard, both the screen and the board move easily out of the clips. I put in a 512GB San Disk and copied the folder structure. Now to transfer my content. Again Thanks so much. I made a 1/2TB iPod for under $100 and it has bluetooth!
Matty - crwdns2934203:0crwdne2934203:0
I'm not able to remove the speaker. I'm using a prying tool but don't know where to insert properly.
tr11ggered - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 42
crwdns2936753:07crwdne2936753:0 184
crwdns2936753:030crwdne2936753:0 657
crwdns2942667:0crwdne2942667:0 5,044
