Initiate the instrument cluster self-test
  1. Initiate the instrument cluster self-test, Save the headlights from excessive use: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • This procedure involves turning on and off the headlights repeatedly, which which can reduce the HID headlights' mean lifetime before failure. As a precursor, consider removing the 15A left & right low headlight fuses from the under-hood fuse box, positions 1 and 6. (Refer to your Owners Manual for instructions, or an iFixit guide.)
    • Be sure to reinstall the low beam headlight fuses before driving the vehicle.
  2. Initiate the instrument cluster self-test, Starting the self test inputs: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Initiate the instrument cluster self-test, Starting the self test inputs: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Initiate the instrument cluster self-test, Starting the self test inputs: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert the ignition key into the ignition lock. Leave it in the 0 or I position.
    • Push and hold the Sel/Reset knob (on the instrument panel by the fuel gauge), or the Sel/reset button on the right hand of the steering wheel below the Multi-Information Display Info button.
  3. Initiate the instrument cluster self-test: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Turn the headlights ON.
  4. Initiate the instrument cluster self-test: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Initiate the instrument cluster self-test: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Turn the ignition switch to ON (position II).
    • Some of the instrument lights will come on. If you aren't wearing your seatbelt, the seatbelt warning chime will sound.
  5. Initiate the instrument cluster self-test: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Initiate the instrument cluster self-test: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Initiate the instrument cluster self-test: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Within five seconds, and still holding in the Sel/Reset button, turn the headlights OFF, then ON, then OFF again.
  6. Initiate the instrument cluster self-test, Final inputs, and here comes the show: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Initiate the instrument cluster self-test, Final inputs, and here comes the show: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Initiate the instrument cluster self-test, Final inputs, and here comes the show: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Within 5 seconds, release the Sel/reset button.
    • Push and release the Sel/reset button button 3 times repeatedly.
    • The instrument cluster begins its self-test.
    • Each successive press of the Sel/reset button initiates a new cycling of all the gauges.
    • To end, turn the ignition switch to OFF, or vehicle speed exceeds 1.5 mph.
    • If you removed the 15A headlight fuses from the under-hood fuse box in step 1, reinstall them before driving.
crwdns2935229:016crwdne2935229:0
David Spalding
crwdns2935283:011/12/15crwdne2935283:0
6,539 crwdns2915208:0crwdne2915208:0
crwdns2947412:05crwdne2947412:0
Folks, don’t post here asking about A COMPLETELY DIFFERENT VEHICLE. This page is for the 2004-2008 Acura TSX (Honda CL9), no others. Keep searching.
David Spalding - crwdns2934203:0crwdne2934203:0
I left decklid open overnight and now my instrument panel is not working
Anthony - crwdns2934203:0crwdne2934203:0
I have an 08 Acura TSX. The lights on the dash are flashing on and off. None of the guages work, neither does the heater. when I plug in my OBD, it throws a U0155 code, lost communication with the instrument panel cluster. The funny thing is, when I plug in the OBD, the instrument cluster work fine, as well as the heat. Please help!
John Dolan - crwdns2934203:0crwdne2934203:0
My 2007 TSX cluster did not enter this self test. Followed 100%. Repeated multiple times still no show.
Bla Bla - crwdns2934203:0crwdne2934203:0
🤷 Sorry, I can only attest for the 2006 model year.
David Spalding -
crwdns2936753:07crwdne2936753:0 85
crwdns2936753:030crwdne2936753:0 448
crwdns2942667:0crwdne2942667:0 320,602
