Infiniti Q50 Bottom Screen Display Replacement
Roberta Willis
crwdns2944109:0crwdnd2944109:0Roberta Williscrwdnd2944109:0crwdnd2944109:0crwdnd2944109:0crwdne2944109:0
crwdns2944111:0Kho 4, 2024crwdne2944111:0
15 - 20 crwdns2931279:0crwdne2931279:0
crwdns2937801:0crwdne2937801:0
crwdns2942287:0crwdne2942287:0
This guide provides instructions for removing the bottom screen display unit of Infiniti Q50 vehicles. The bottom screen should allow you to access navigation, audio controls, climate settings, vehicle diagnostics, and other vehicle information. If your screen is damaged, glitching, or not turning on at all, it may be time to consider a replacement.
For your safety, it is recommended that you do not park on an incline when working on your repair. Be sure to park on level ground. You might find it easier to complete Step 4 by setting your gear shift to neutral. If that is the case, be sure to engage your emergency brake to prevent the car from moving.
  1. Infiniti Q50 Bottom Screen Display Replacement, Bottom Screen Display: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Infiniti Q50 Bottom Screen Display Replacement, Bottom Screen Display: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Infiniti Q50 Bottom Screen Display Replacement, Bottom Screen Display: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a panel popper or screwdriver to pop out the side panels of the center console.
  2. Infiniti Q50 Bottom Screen Display Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Infiniti Q50 Bottom Screen Display Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Infiniti Q50 Bottom Screen Display Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift and remove the cup holder piece.
  3. Infiniti Q50 Bottom Screen Display Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Push down on the gear shift to reveal the clip.
  4. Infiniti Q50 Bottom Screen Display Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Make sure to engage your emergency brakes and put the car in neutral gear before proceeding with this step.
    • Use a screwdriver to remove the clip from the gear shift.
    • Store this clip in a secure location for safekeeping.
    • Pull off the gear shift knob.
  5. Infiniti Q50 Bottom Screen Display Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Infiniti Q50 Bottom Screen Display Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the two screws found underneath the side panels.
  6. Infiniti Q50 Bottom Screen Display Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Wiggle to lift the center console over the gear shift.
  7. Infiniti Q50 Bottom Screen Display Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Infiniti Q50 Bottom Screen Display Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pinch the tip of each connector cord to detach from the center console.
  8. Infiniti Q50 Bottom Screen Display Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Infiniti Q50 Bottom Screen Display Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Infiniti Q50 Bottom Screen Display Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull off the trim found on either side of the display screen.
  9. Infiniti Q50 Bottom Screen Display Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Infiniti Q50 Bottom Screen Display Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the two screws underneath the trim.
  10. Infiniti Q50 Bottom Screen Display Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Infiniti Q50 Bottom Screen Display Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Wiggle to pull out the bottom screen display.
  11. Infiniti Q50 Bottom Screen Display Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Infiniti Q50 Bottom Screen Display Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pinch to detach the connector cords.
crwdns2947821:0crwdne2947821:0
crwdns2947823:0crwdne2947823:0
Roberta Willis
crwdns2935283:002/19/24crwdne2935283:0
203 crwdns2915208:0crwdne2915208:0
crwdns2936753:030crwdne2936753:0 57
crwdns2942667:0crwdne2942667:0 630
