This guide shows how to rebuild the projector lanp in your InFocus Scereenplay 4805 projector. You will need a replacement bulb and an iFixit tool kit.
Slide the bulb housing out of the projector.
Use the Phillips #1 screwdriver to remove the three 1 cm gold screws on the bulb housing.
Gently pull the top of the bulb housing off.
Lift up the middle of the bulb housing to remove it.
Unhook the spring from the bulb housing.
Gently remove the bulb.
crwdns2935219:0crwdne2935219:0
To reassemble the device, follow these instructions in reverse order.
