IdeaPad L340-15API Battery Replacement
crwdns2869540:0crwdne2869540:0: 695
6
28
146
695
crwdns2959984:0crwdne2959984:0: 0
crwdns2959956:0crwdne2959956:0
crwdns2955944:0crwdne2955944:0: 10 - 25 crwdns2931279:0crwdne2931279:0
crwdns2955970:0crwdne2955970:0: crwdns2937799:0crwdne2937799:0
crwdns2862591:0crwdne2862591:0
crwdns2862592:0crwdne2862592:0
The battery is a critical component that keeps your device powered. It supplies energy to all parts of the laptop and must hold a charge long enough to make the device portable.
If your laptop can’t hold a charge or must remain plugged in to stay on, the battery is likely the cause.
This guide shows how to replace the battery in a Lenovo IdeaPad L340-15API.
Before you begin, power off the laptop and disconnect the charging adapter and any external peripherals.
    1. IdeaPad L340-15API Battery Replacement, Optical Drive: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 IdeaPad L340-15API Battery Replacement, Optical Drive: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Before beginning the repair, make sure that the device is fully powered off.
      • Turn the laptop over so the bottom cover is facing up.
      • The small screw hole near the center of the case, marked with a tiny DVD icon and an arrow, secures the optical drive.
    2. IdeaPad L340-15API Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 IdeaPad L340-15API Battery Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Use a Phillips #1 screwdriver to remove the 7.5 mm screw securing the optical drive.
      • Place the screw down safely in a container/magnet strip where it will not get lost while you are working. These screws are very small and easily misplaced.
    3. IdeaPad L340-15API Battery Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 IdeaPad L340-15API Battery Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Place your thumb at the seam between the optical drive and the device.
      • Gently pull the component straight out from the device, taking care not to pull at an angle.
    1. IdeaPad L340-15API Battery Replacement, Battery: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 IdeaPad L340-15API Battery Replacement, Battery: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Use a Phillips #1 screwdriver to remove the twelve 7.5 mm screws from the back cover.
    2. IdeaPad L340-15API Battery Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 IdeaPad L340-15API Battery Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 IdeaPad L340-15API Battery Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Insert a plastic opening pick in the back left corner and wedge the panel open.
      • Slide the pick around the edge of the laptop to release the clips as you lift the panel.
      • If the opening pick isn’t working, use the iFixit opening tool to gain more leverage.
      • Remove the bottom cover.
    3. IdeaPad L340-15API Battery Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 IdeaPad L340-15API Battery Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Use the Phillips #1 screwdriver to remove the five 6.5 mm screws securing the battery.
      • Use a container/magnet strip to store the screws while working.
    4. IdeaPad L340-15API Battery Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 IdeaPad L340-15API Battery Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 IdeaPad L340-15API Battery Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Use the wide end of a spudger to push the connector tab, sliding the battery connector out of its socket.
      • It may take a lot of force to disconnect the cable. Go slowly, and don't pull on the cables.
    5. IdeaPad L340-15API Battery Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the battery from the laptop.
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
For optimal performance, calibrate your newly installed battery after completing this guide.
Ian
crwdns2935283:010/15/25crwdne2935283:0
347 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team 2-5, Bowman Fall 2025 crwdns2935289:0UMass Dartmouth, Team 2-5, Bowman Fall 2025crwdne2935289:0
UMASSD-BOWMAN-F25S2G5
crwdns2935297:048crwdne2935297:0
crwdns2936753:030crwdne2936753:0 146
crwdns2959996:0crwdne2959996:0 695
